Old 27-04-2018, 03:20 PM   #106
ZA-J
Originally Posted by Chris16v View Post
I don't think this will have caused your issue, but I would personally slide the 90degree rad hose by the vvc belt cover down about 2" if you can? Looks like that sits higher than the elbow going into the rad and could cause an air lock at that point.
It's as low as it can be. Already modified the hose layout a few times to get it like this :/
Old 04-06-2018, 09:51 AM   #107
ZA-J
After some driveshaft teething issues (too much float on the Mini end), she's finally on the road in time for the sunshine - pic taken at a local car show yesterday.
Old 04-06-2018, 11:45 PM   #108
Proper. Job, how's it behaving on the road?
Old 05-06-2018, 06:57 AM   #109
ZA-J
So far so good, just needs wheel alignment fine tuning. I've been TRYING to drive sensibly for a shakedown run, but not managed too well so far
Old 05-06-2018, 07:37 AM   #110
Our cars are not supposed to be driven sensibly! that's why we've built them
Old 05-06-2018, 07:59 AM   #111
ZA-J
Only because I've not done a nut and bolt check since building it yet. Normal service will be resumed shortly
Old 05-06-2018, 11:57 AM   #112
Did you notice this test track ?
http://www.16vminiclub.com/forums/sh...ad.php?t=37693
Old 05-06-2018, 01:07 PM   #113
ZA-J
Ah raspberry, I'm at a show at Goodwood that weekend
Would definitely be there otherwise.
Old 24-06-2018, 08:18 PM   #114
ZA-J
I became a member of the bonnet off w@nkers car club this weekend at Goodwood. Car behaved perfectly on the 120 mile round trip
Old 28-07-2018, 11:27 AM   #115
ZA-J
First trip to a drag strip a few weekends ago......Would like to try some slips next time as it was spinning in all gears down the track.
OOO_0035 by Andy Walker, on Flickr
Old 28-07-2018, 11:54 AM   #116
That's useful times I wonder if the resurfacing has helped maybe don't seem like it has when you mentioned spinning in all gears, or do you think it was other reasons?
Old 28-07-2018, 04:53 PM   #117
Decent times if I may say. Car looks good.
The first time I went, me and my mate Martin shared the driving. I was running 14.9, he was running 15.0 along with Garv who has never forgotten that day!
I have tried slicks. They gain the most in the 60ft section. You should be around the 2.0 seconds there. The rest of the track, use the max gas you can without spinning. It's all good fun.
I still need to visit again with the Quaife and slicks. Hoping to get under 14 seconds when I do. I haven't done any power modifications. Just grip!
Don't get carried away with these times. It's addictive. People will come saying do this and that and you'll improve. A few grand later and a non roadworthy car, you might regret it!
Old 28-07-2018, 08:05 PM   #118
ZA-J
The big boys are all posting faster and quicker times on the new track; I went to the doorslammers event earlier in the year and the there were three or four new European records, but that was a prepped track.
Iíd be interested to see how much better the van is on slicks and with wheel alignment sorted. Itís miles off at the minute.
I can see how people end up turning street/strip cars into fully blown race cars; itís very addictive!
