Old 28-09-2016, 11:04 AM   #1
Bigredmini94
Bigredmini94's Avatar
CC: 1800 t
Default 1000cc TO 1800cc turbo :)
Sorry for leaving it so long but i think its about time i do a build thread for mini.
Ive still got bits left to do but its nearly there the build so far :
Watsons front subframe
6 point cage
Mg zt t engine standard turbo
K maps ecu
Clubman front fibreglass
Perspex windows
Rear mount radiator
Fibreglass doors / rear valance
Koso digi dash
C6 gearbox (need lsd )
Fse rising rate fuel regulator
Walbro fuel pump
Rose joint engine steadies
Theres lots of other little bits but just a quick run down, had lots of grief doing bits but thanks to you guys using your build thread etc its helped a hell of a lot .
Its a big shock 2 the system for a first build not knowing how to get round things and you feel like giveing up but the first drive is the dogs bollocks lol .
Ill try to upload some photos for you all 2 look at.
Thanks lewis
Bigredmini94 is offline   Reply With Quote
Old 28-09-2016, 11:23 AM   #2
Bigredmini94
CC: 1800 t
Haveing problems loading the photos ill set up a photo bucket account but a little walk round of the car so far .
Old 28-09-2016, 03:21 PM   #3
Heated passenger seat, nice!
Build looks good, interesting how you have done the rad in the boot.
Old 28-09-2016, 03:50 PM   #4
I have near identical cooling pipes under my passenger seat with my rear mount radiator and it does get very hot in traffic in the cabin
Old 28-09-2016, 06:32 PM   #5
uksnowman
it sounds savage. looking forward to seeing the build photos
uksnowman is offline   Reply With Quote
Old 22-04-2018, 04:41 PM   #6
Bigredmini94
CC: 1800 t
Haven't touched this much since last year ... I also keep for getting to do a build thread
I've changed to an allspeed frame and painted the car and put rad up front my workmanship isn't as good as a lot of people on here but its practical
Here's as it stands .....
Sent from my ONEPLUS A5010 using Tapatalk
Old 24-04-2018, 03:44 PM   #7
Any reason for changing the subframe? Seems funny as Charly has swapped from Allspeed to Watson's but he was snapping driveshafts like twigs! On that note, what driveshafts are you using?
What happened to the front cross member? Has it disappeared?
Old 24-04-2018, 03:52 PM   #8
Bigredmini94
CC: 1800 t
It's was mainly the suspension set up I just didn't like the feel of it still got the frame in case have to go back .... the wheel options was quite slim it may be worse it might be better will not know till I've tried . Shafts are sleeved and welded not running as much hp as his 1.. hd outer CV joints , the front cross is in the shed dw I haven't forgot to put it on .
Old 30-04-2018, 06:01 AM   #9
Charly was snapping them at the Mini outer hub end where the splines start, itís a weak point.
If your running the HD CVís then you should be ok.
Old 03-06-2018, 07:05 AM   #10
Bigredmini94
CC: 1800 t
Took the the car for a test drive last night excluding a steering issue, i need the alignment done everything was good ... Except I don't know if the mini rads will be up to the job only went round the block and it's sitting around 100 is this right ? I couldn't really see what it does on a stretch long bit of road couldn't go far with it ... But here's some photos .
Think the quickshifts best thing I've changed on it so far
I love get a couple of the inside later ..
Old 03-06-2018, 07:39 AM   #11
On the standard car the fan doesnít kick in until 104 so 100 is ok, ideally normal running temps would be in the low 90ís.
The Mini rad will be fine, there are a couple of things you can do if your concerned, first of all you can try fitting a NEW expansion tank cap to make sure the system is pressurised,if that doesnít work then I would fit an 82degree thermostat which will open earlier and keep temps lower.
Old 09-06-2018, 04:47 PM   #12
Bigredmini94
CC: 1800 t
https://youtu.be/hQ08fMpAQQA
Took the car for geometry today i didn't realise got slight play in inner tie rod on nearside does anyone know if you can replace just the arm ?
Settings as follows I explained it's just track car and asked what he recommends so we went with this obviously it's down to my feed back but car felt good .
Caster 5 degree
2.5 degree camber
And slight toe in 5 minutes, we tryed parallel toe but car didn't want to go straight when I tested it it sort of fought it's self, still struggle a little but the slight toe in has helped.
Old 09-06-2018, 07:48 PM   #13
Well done... Can I hear a slight misfire in the video?
Old 09-06-2018, 08:21 PM   #14
Bigredmini94
CC: 1800 t
It's not a misfire it's me letting off a little then back on power can only really get the power down and keep it completely straight when tyres are really warmed up but still get slight wheel spin every now and then still got a open diff atm tho .
Old 09-06-2018, 10:46 PM   #15
GEORDIE SP1
GEORDIE SP1's Avatar
Default 1000cc TO 1800cc turbo 😊
You can adjust inner steering arm, take boot off, locking ring behind steering arm ball joint, release the locking tabs screw the inner ring back a bit the screw the ball joint cup up to it
Donít leave it to tight
Tighten the ring against the joint again and tap locking tabs back in. Thatís if itís a mini rack ??
