Old 24-02-2018, 10:00 PM   #406
CooperWorks
CooperWorks's Avatar
ECU: Mems 3
Thumbs up
Looking good mate
Old 26-02-2018, 08:30 AM   #407
Excellent
Originally Posted by chabbly vvc View Post
I'd seriously consider replacing the rubber with polybushes. I have them on mine and there is no squirming under power etc
Old 26-02-2018, 12:54 PM   #408
Cliff Pountney
Hi. Looking good.
What wheels are you running? I've been using some 6 spoke Metro GTA wheels which are 5.5J wide, but those seven spokes you have look wider. Where did you get them from?
Thanks,
Cliff
Old 26-02-2018, 02:31 PM   #409
Originally Posted by Cliff Pountney View Post
Hi. Looking good.
Thanks,
Cliff
They're OEM 7 spoke Metro GTi wheels, also 5.5x13
Old 01-04-2018, 08:55 PM   #410
chabbly vvc
chabbly vvc's Avatar
Been busy this weekend finishing of the manifold/ down pipe
Old 01-04-2018, 09:08 PM   #411
I think I just had a little sex wee!
Old 02-04-2018, 09:16 AM   #412
Charly, what is that on the top of the manifold?
Old 02-04-2018, 10:48 AM   #413
External waste gate.
Old 02-04-2018, 02:30 PM   #414
chabbly vvc
Itís an external waste gate. This should cure my boost creep issues as the standard waste gate on the turbo wasnít up to the job.
Old 08-05-2018, 11:31 AM   #415
chabbly vvc
Put a few hours in this weekend...
Old 08-05-2018, 03:14 PM   #416
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Looking good mate, makes me want to get my finger out and get on with finishing mine
