Old 24-10-2017, 08:07 PM   #121
jackjewell93
ECU: Emerald
Haven't got a clue started stripping it and can't see anything obvious yet
jackjewell93 is online now   Reply With Quote
Old 24-10-2017, 08:08 PM   #122
CooperWorks
CooperWorks's Avatar
ECU: Mems 3
Thumbs down
Originally Posted by jackjewell93 View Post
Not well itís dead lost all oil pressure seized up! Engine is now in bits proper grapesed off!
Sorry to hear this fella
Old 24-10-2017, 08:16 PM   #123
Old 24-10-2017, 08:24 PM   #124
Broomel
Oh bananas!
Any idea what failed?
Yeah, he failed to wire up a oil light or gauge.
Old 19-11-2017, 03:34 PM   #125
jackjewell93
ECU: Emerald
So after a full strip down the oil pickup was blocked with all sorts of pineapple. Pretty much everything has gone in the bin apart from the crank rods and block ordered new mahle Pistons crank has been sent off for a re grind bought another head that's had some porting work done, new valves and tappets, need to sort out some liners not sure what to get yet, also pretty much bought an allspeed frame just waiting for them to take it out thought while everything is out might aswell put a tried and tested frame in after all it's going to have 200plus horse power.
Old 19-11-2017, 04:10 PM   #126
Shit, what seazed then?
Old 19-11-2017, 04:34 PM   #127
jackjewell93
ECU: Emerald
Seized up on the big ends
Old 19-11-2017, 04:45 PM   #128
you best throw the crank away then
Old 19-11-2017, 04:47 PM   #129
jackjewell93
ECU: Emerald
Taken it to the machine shop it's gone for a re grind
Old 19-11-2017, 04:50 PM   #130
good luck with that then, normally no room left after a seaze up like that
Old 19-11-2017, 05:59 PM   #131
You need to look at the stuff that blocked the oil pickup in the first place and figure out exactly what it is and where itís come from or you risk blocking it up again.
If itís sealant then you could be using too much when your assembling the engine, if itís metal then something else was wrong before the engine seized.
Old 03-12-2017, 09:01 PM   #132
jackjewell93
ECU: Emerald
Collected all the parts back from the machine shop and started the re assemble of the engine.
Old 17-12-2017, 04:57 PM   #133
jackjewell93
ECU: Emerald
Engine is finished and re assembled got a week off work over Xmas so hoping to get engine back in over that week
Old 17-01-2018, 09:14 PM   #134
jackjewell93
ECU: Emerald
Default 1.8 turbo (round nose)
Got the engine back in its all back together hopefully be mapped soon!
Old 28-01-2018, 08:34 PM   #135
jackjewell93
ECU: Emerald
Ive Remade the dash, got the oil pressure, oil temperature, and boost gauge fitted also ordered a emerald loom for the engine that will be getting wired up when it gets mapped
Sent from my 4047X using Tapatalk
