Old 10-01-2018, 10:18 AM   #1
baz_rsp
baz_rsp's Avatar
Default C20xe starter to alt wiring picture please
As title. I havenít looked at the wiring for my mini for a few years and Iím a bit lost. Was hoping someone could share a picture of what wire goes where. I have done a search but most links/picture donít open.
Thanks.
baz_rsp is offline   Reply With Quote
Old 10-01-2018, 08:48 PM   #2
Muffyvaux
Muffyvaux's Avatar
Main thick cable from the battery to the big terminal on the starter motor. You can put a big fuse in that line if you want.
Output from the alternator to the same big terminal on the starter motor.
Old 11-01-2018, 09:19 AM   #3
baz_rsp
baz_rsp's Avatar
So what goes the the little terminal in the starter? You got a picture of your setup?
Old 12-01-2018, 08:27 AM   #4
The positive to the starter solenoid that is activated by the ignition?
Old 20-01-2018, 02:31 PM   #5
baz_rsp
baz_rsp's Avatar
Sorry for the late reply. I have sorted the starter problem. The car now turns over. Now my problem is the alternator. As I’m using a etb digidash I have not batt warning light that connects to the alt. So I need to know what wires go where. I rigged a light to the + on std xe alt and ign live. (Light comes on) fine. I connect battery live from starter light goes off with out cranking the engine. Check voltage across the + and d+ and getting a 2v. Is the + not meant to be a - until the engine starts?
Old 31-01-2018, 03:31 PM   #6
robbob1980
I've just had to wire up an alternator light after swapping to an acewell dash. I ran a +12v ignition switched live to one side of the light, then the other side of the light goes to the alternator warning light wire which used to go to the vauxhall clocks.
Rob
robbob1980 is offline   Reply With Quote
