Old 12-10-2017, 08:49 PM   #1
Lancashirehotrod
ECU: Canems
Default Turbo x16xe
I've had my x16xe powered fixed steel round nose mini on the road over the summer and it is great fun but I think the allspeed set up can handle more power so I'm going to mount a turbo under the rear subframe and blow through the zx9r carbs. Does anyone have any tips?
Lancashirehotrod is offline   Reply With Quote
Old 13-10-2017, 07:59 AM   #2
http://www.16vminiclub.com/showthread.php?t=6055
This is the best documented remote turbo thread I know on here
Old 14-10-2017, 07:39 AM   #3
Lancashirehotrod
ECU: Canems
Thanks for that. Does anyone know what boost I can run on the standard internals? I have arpeggios rod bolts and spd cam belt pulls and it's the x16 Xel so it's lower compression 8.8-1 i believe. I'm only looking for +30//40bhp. As I'm aiming for a reliable and usable 180bhp. With more torque. Thanks in advance.
