Old 17-08-2017, 09:22 PM   #1
Basil
CC: 1598
Default x16xe what size throttle bodies
I am in process of building a x16xe engine, spec will be ported and polished head, canems ecu, reprofiled cams, exhaust manifold and straight through exhaust.
I am hoping for 170+ bhp, what size ITB's should I use, I have the option of 40, 42 or 45mm.
Old 19-08-2017, 04:14 AM   #2
by my world 45 is to big, defo no,, i recon start with 40 then rolling road,
170 is tops? yes? or no?
Old 20-08-2017, 07:36 PM   #3
Basil
CC: 1598
currently spec should be good for about 180? I don't have much detail on the cams, but reprofiled cams tend to be similar as there isn't too much that can be done.
Only other change I am considering is using 1.8 pistons and crank, should be good for another 10bhp?
Old 21-08-2017, 01:12 AM   #4
exspanding the cubes is a good move provideing it dont chuff with bore wobble,
cc is best so yes!
and if cost is ok for bang for buck,
eather way you will have 5 gears and 100 hp in a mini is fine,
nice job
