Old 15-08-2017, 04:41 PM   #1
spudgun
spudgun's Avatar
ECU: none
Default BMW MINI Pedal box
Has anyone used the pedal box from one of the new BMW Minis? By the looks of it with a bit of work it may fit.
spudgun is offline   Reply With Quote
Old 15-08-2017, 06:09 PM   #2
Which generation ? My Countryman (R60 - Gen2) has a servo that connects directly to the shaft of the pedal under the pivot, if you tried to fit that to a Classic Mini the servo or master cylinder would poke through bulkhead into engine bay under the crossmember
Old 15-08-2017, 07:59 PM   #3
spudgun
spudgun's Avatar
ECU: none
Default BMW Pedal box
I didn't know there was a difference. I had a very quick look this morning to see what was about and came across a R53 I think. It looked like the master cylinder was vertical below the pedal. That's what got me thinking. I have zero room above the lower dash shelf.
Old 15-08-2017, 08:08 PM   #4
spudgun
spudgun's Avatar
ECU: none
Default BMW pedal box
Just had another look and it's an R50 (2005 Cooper)
