Old 05-08-2017, 08:15 AM   #1
pipsovich
Default X16XE hydraulic clutch slave cylinder
Hello!
I need to buy the hydraulic clutch slave cylinder for my X16XE.
Does anyone have the part number or from which car i can buy it from?
Peter
Old 11-08-2017, 06:50 AM   #2
M J W J
M J W J's Avatar
You need one from either an f13, f15 or f17 gearbox.
They should be available in mk4 Astra's onwards.
If you check the diameter of input shaft on your gearbox I might have one. I'd need to check if it's for the f13,15,17 or F16,F18,20 gearbox.
Old 23-08-2017, 07:26 AM   #3
pipsovich
Hello.
Slow answer from me... Sorry, but i have been fixing rust all the time!
So i need to check what gearbox i have first, then i know which one i need to buy.
Did you check if you had one?
Old 23-08-2017, 05:27 PM   #4
pipsovich
Is this the right one?
https://www.bildelsbasen.se/se-sv/Op...2/OEM-24424957
