Old 15-07-2017, 08:49 PM   #1
Mini Vlatko
Mini Vlatko's Avatar
Default MS start map
Ok guys, as the "first start" time is getting closer I'm trying to gather all necessary things to do it right.
One of those "things" is a Megasquirt map...
My setup is not so unusual...it's a standard redtop with GSXR throttle bodies and custom exhaust manifold...
Can someone share the start map?
Thanks!
Old 19-07-2017, 12:08 PM   #2
Muffyvaux
Muffyvaux's Avatar
When I first started mine the base map tuner studio created was good enough to start.
Ben
Old 20-07-2017, 06:30 AM   #3
Mini Vlatko
So the Tuner studio creates the map?
Could you explain it some more?
Thx
Old 21-07-2017, 06:00 PM   #4
Muffyvaux
Muffyvaux's Avatar
In the engine parameters you select capacity number of cylinders etc and injector flow rate. Tuner studio will give you a basic map which should get the engine running.
Ben
Old 21-07-2017, 07:32 PM   #5
Mini Vlatko
Well that is exactly what I need! Thank you on that info!
