Old 19-04-2017, 08:07 PM   #1
Lancashirehotrod
ECU: Canems
Default x16xe fixed steel round nose
hello fellow 16v mini builders. i have been learning lots from this forum and thought you'd like to see some pictures.
Lancashirehotrod is offline   Reply With Quote
Old 15-05-2017, 06:10 PM   #2
knoxy
I thought getting mine in the clubman front was tight.
Old 16-05-2017, 12:11 PM   #3
pipsovich
That looks awesome. Using your own subframe or bought?
What radiator is that?
Im currently in the beginning if a steel fixed round nose x16xe build!
Old 31-10-2017, 05:05 PM   #4
cherrybomb
CC: 1598
ECU: dta
Looks a lot like ,mine ! What pedal box/ brake master and induction you using ?
cherrybomb is offline   Reply With Quote
Old 21-11-2017, 07:34 PM   #5
Lancashirehotrod
ECU: Canems
Im using a modified mk1 escort bias pedal box with three willwood master cylinders and its zx9r carbs on a bogg brothers manifold. I'll have a look at yours do you have a build on here?
