Old 05-01-2017, 03:47 AM   #1
minicoon
Default BMW K1200RS TPS Problems
Hi,
I am having some trouble calibrating the TPS in my Microsquirt EFI for a K1200RS conversion.
The computer is looking for an upper and lower resistance level which is different from the signal that the 4 pin TPS is giving and hence giving a screwy output.
has anyone else seen this problem or heard of a fix for it?
Mark
minicoon is offline   Reply With Quote
Old 05-01-2017, 08:05 AM   #2
yep , same issue , i swapped to a 3 pin ,
basically the bike TPS has two tracks, one gives good detail 0 to 5v from 0 to 25% ( guessing figures ) and the 2n gives good detail from 25% to 100% , 0 to 5v , so maybe there is a good / nice way to wire it up , but i fitted a 3 pin TPS from a vauxhall in the end
inside BMW :
and the adaptor plate my dad made / adaptor pin :
Old 05-01-2017, 10:43 PM   #3
hydrolastic
Yes, had the same problem and swapped to a buick one on a throttle body. http://www.ebay.com/itm/Throttle-Bod...1S~4R5&vxp=mtr Also changed the crank sensor to a volvo one cause i just could not get the
fiat one to work. The crank trigger wheel was also evened out (Symmetrical teeth) The rest of the sensors were GM i think except the OX sensor but there i used the Bosch which also ran the AF gauge. The Megasquirt system also needs a special coil since it is lacking some kind of code to read a standard coil turns out a coil from a new beetle was a plug in because it is compatible with the megasquirt. Since the conversion the sensors have been trouble free and it fires up on the third revolution of the engine everytime. Hydro
hydrolastic is offline   Reply With Quote
Old 07-02-2017, 12:28 AM   #4
mic
Send a message via MSN to mic
Can I ask why you (or anyone else it seems) don't use the original coil packs from the BMW engine?
mic is offline   Reply With Quote
Old 07-02-2017, 07:40 AM   #5
1) I did not get them with my head
2) i know MS works perfect with the coil pack i head , so saved lots of experimenting time trying to get it to work with other coil packs.
