Old 18-02-2017, 05:29 PM   #46
no-dice
No idea yet, not fitted yet.
Hope soon though
no-dice is offline   Reply With Quote
Old 19-02-2017, 02:45 PM   #47
McMini 22
Do not put a band on that right driveshaft inner joint boot at this stage. I couldn't fit the pot joint through the hole in the subframe so fitted the pot joint to gearbox then slid the driveshaft, boot and inner cage through the hole. Grease everywhere!
Old 19-02-2017, 03:30 PM   #48
no-dice
Think we broke the gearbox
Think it was in gear when we started it up without any shafts in
Fuck!!!!
Old 19-02-2017, 08:49 PM   #49
no-dice
Got a few jobs sorted today, battery cables, throttle cable and mounted flip front.
Car sounds amazing
Was gunna put shafts on, but wouldn't go in.......think we left it in gear whilst engine was on with shafts out at some point
Is it salvageable?
Old 19-02-2017, 09:31 PM   #50
no-dice
https://youtu.be/HqEv21bhFPU
Old 19-02-2017, 10:04 PM   #51
robert_paull
Loving your work
robert_paull is offline   Reply With Quote
Old 19-02-2017, 10:06 PM   #52
robert_paull
What ecu are you using
Old 19-02-2017, 10:13 PM   #53
no-dice
It's a megasquirt clone
It's sold here as a redline developments ecu, but it's a k-data unit
