Old 19-08-2016, 08:46 PM   #31
no-dice
Cheers mate, was enjoying your build until it was lost
no-dice is offline   Reply With Quote
Old 19-08-2016, 10:22 PM   #32
McMini 22
My build is over on The Mini Forum. There were more people over there doing micra swaps.
I am making progress but still loads to do.
Old 27-08-2016, 09:43 AM   #33
no-dice
Was meant to be first start this weekend, but fuel rail leaks and ecu ingnition drivers died
Old 02-09-2016, 06:31 PM   #34
no-dice
Think I've cured the ecu problem, coils don't blow there fuses anymore, fixed fuel rail too
Ran out of time due to work, so can't get to try it out until Tuesday!!!
Old 06-09-2016, 04:45 PM   #35
no-dice
It's alive
https://youtu.be/r0l-Vho9aUM
Old 06-09-2016, 10:50 PM   #36
McMini 22
Brilliant. Must be a great feeling to achieve this major milestone.
Old 07-09-2016, 06:30 AM   #37
no-dice
Yeah was great, wasn't running on all 4, think I had injector pins wrong places lol
The car lives 50 miles away so not that easy to just go out and play with it
Old 07-09-2016, 02:45 PM   #38
no-dice
Running on all 4, that screeching noise is the gasket between the charger and the black throttle mount, need to finish exhaust up to get rid of the other noises
https://youtu.be/C3JLcmGYPlk
Old 08-09-2016, 12:55 AM   #39
brill, is the blower belt long? im not used to long blow jobs.
Old 08-09-2016, 05:41 AM   #40
no-dice
Haha!
I Spose it's quite long from charger to alternator, but it's short from the other pulley.
I do need to brace the charger against somthing though, there's a tiny bit of flex on the moubt
Old 15-09-2016, 06:49 PM   #41
no-dice
Got all final pieces for exhaust
Battery cables and battery sorted, jus need. Drive shafts and we can go for a test drive!!
Old 22-09-2016, 01:53 PM   #42
no-dice
Zorst all welded up
Need to figure out wiring for alternator,
I know it's a very basic thing I should know, but where do the wires go lol
Old 23-09-2016, 05:17 PM   #43
fuzzy-hair-man
I just googled denso or Suzuki alternator wiring and it came up for mine, I later had some trouble because I was getting the battery going flat, I'd used an adapted micra loom which had a permanent live to the alternator but the Suzuki alternator expected a switched live. Just in case it catches you out too...
fuzzy-hair-man is offline   Reply With Quote
Old 17-02-2017, 12:43 PM   #44
no-dice
Shafts finally done!
Old 18-02-2017, 05:13 PM   #45
robert_paull
Stella work top marks
Did the Shafts vibrate at all as they were not balanced
robert_paull is offline   Reply With Quote
