Old 18-07-2016, 06:41 PM   #16
no-dice
Tonight's activities........maybe should of used more colours lol
But the black was free
no-dice is offline   Reply With Quote
Old 19-07-2016, 08:51 AM   #17
McMini 22
What about putting different coloured heatshrink bands on the ends of the wires to help with any future wiring problems? (A bit like the bands on resistors)
We used to use numbered sleeves in the Avionics industry with all white or pink wire.
Build is looking great by the way. Good progress!
Old 19-07-2016, 08:56 AM   #18
no-dice
Cheers. I know i don't help myself
It's ok though , I've wired this ecu up about four times in different cars I've had
Getting closer now to actually starting the engine, just needs shafts and gear linkage
Old 19-07-2016, 09:35 AM   #19
McMini 22
Have you any more info on the ECU? Just had a Google and couldn't see very much as there is not much info on their website.
I'm looking at a Microsquirt in the future but could be persuaded otherwise.
Old 19-07-2016, 09:39 AM   #20
no-dice
It's a k-data ecu, rebadged as redline developments
http://redline-developments.com
It's a mega squirt copy, cost me 325, and uses the tuber studio software
Old 19-07-2016, 11:58 AM   #21
no-dice
Gauges in and dash done
Old 19-07-2016, 01:52 PM   #22
no-dice
Rad on
Just dropped off mini/micra shafts to engineer bloke to make up some sleeves for me
Old 05-08-2016, 09:25 PM   #23
no-dice
Gear linkage done, took a lot longer than it should!!!
Old 19-08-2016, 12:31 PM   #24
no-dice
Few jobs done
Dash in
Wiring progress
Old 19-08-2016, 01:01 PM   #25
Originally Posted by no-dice View Post
Rad on
I'm not sure how much cooling effect you'll get with your rad at that angle, can it be straightened up any so it is flatter to the front ? The more angled the rad the less frontal surface area for the air to flow through and is more likely to deflect the air off the face of the rad than go through it as air will always take path of least resistance (ie around rad rather than through it)
Old 19-08-2016, 01:04 PM   #26
no-dice
If I could, I would of mate, havnt even got the fan on yet, and that needs to go on the front of it too
Old 19-08-2016, 03:58 PM   #27
McMini 22
But the Mini one is 90 degrees to the front of the car and that works?
Old 19-08-2016, 08:23 PM   #28
having the radiator at such an angle as 1/3 of the core area is exposed from straight on (but ducted so all the core see's the air) is actually more efficient than running the radiator heads up fully exposed. something to do with how the airflow slows down as it hits the core. I see no problem here, worked on plenty of cars with a "V-mount" radiator and intercooler setup, perfectly fine
EDIT you will need to duct tho as air will frow thro the grille and out the arch never touching the radiator.
Old 19-08-2016, 08:24 PM   #29
no-dice
cool
Coz it has t stay there
Old 19-08-2016, 08:45 PM   #30
McMini 22
cool
There is a saying - necessity is the mother of invention. When it comes to fitting a 16v in a Mini it should be necessity is the mother of compromise!
My radiator will be in the standard mini position and hopefully it will be ok. Then again, I won't be running a supercharger.
Great progress!
