Old 23-05-2016, 12:09 PM   #1
no-dice
Default Project: poopercharger (cg13de micra)
Well loosing all my thread sucks!!
Here's a quick re-cap from photos I've managed to find
Homemade frame
Repaired rear subframe
Supercharger/inlet manifold made from various old manifolds
Homemade exhaust
New water pulley made to be inline with other pulleys
Clutch pedal
Brake servo relocated to passenger side, made a cam bar with a few rose joint connectors
Would of used original m/c, but charger covers the holes
no-dice is offline   Reply With Quote
Old 23-05-2016, 12:45 PM   #2
no-dice
Car now rolls on its wheels for first time in its new life
Old 24-05-2016, 07:50 AM   #3
Alex1380
ECU: Megasquirts
looks like we have matching wheels.
Old 07-07-2016, 02:51 PM   #4
no-dice
Inspired by all the cool minis at retro show at Santa pod, decided to pull my finger and get back on the car
Injection pumps and stuff sorted with return welded onto the tank
Brake lines done
Should have this soon too
Old 08-07-2016, 01:59 PM   #5
no-dice
Coils and injectors wired up
Old 08-07-2016, 04:48 PM   #6
no-dice
Anyone used one of these?
http://www.carbuildersolutions.com/u...-wiring-module
Old 09-07-2016, 08:21 AM   #7
Pikey
CC: 2.0
Yeah I have, good but of kit and easy enough to wire up aswell. I've used it but blended it in with mini switches, stalks etc and so far it's all working great. Only thing is may need to add an extra fuse box if your planning on using more electrical components than the module has room for. Check out my diary of you like. Cheers
Old 09-07-2016, 08:22 AM   #8
no-dice
Cheers will do
Old 09-07-2016, 04:22 PM   #9
Can I just ask... did you beef up that subframe in certain areas, as it looked pretty weak in some areas from earlier pictures. I know its a micra engine, but now you've a supercharger and the engine / trans loads are just one aspect.
Old 09-07-2016, 04:23 PM   #10
Sorry not trying to cause grief but rather avert it.
Old 09-07-2016, 04:25 PM   #11
no-dice
No problem mate.
Yeah, triangulated some parts and extra bracing here and there
Had some photos, but lost when the server crashed and could only salvage what I've reposted
I'm confident it's strong enough
Old 09-07-2016, 04:27 PM   #12
Originally Posted by no-dice View Post
No problem mate.
OK cool. It's just sometime earlier in builds, frames not unlike tv stands are created.
Old 09-07-2016, 04:32 PM   #13
no-dice
I've looked over a few frames, also the allspeed type, so just copied those really and strengthened where I think looks like it needs it
Old 12-07-2016, 02:58 PM   #14
no-dice
Ecu wiring 99% done with relays fuses and switches
Old 15-07-2016, 10:09 PM   #15
no-dice
