Old 26-04-2016, 11:58 AM   #16
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
Good work, will be quick when done!
Old 26-05-2016, 08:06 PM   #17
minisilverbullet
Well it arrived…..
minisilverbullet is offline   Reply With Quote
Old 27-05-2016, 11:20 AM   #18
minisilverbullet
A quick question:
Should i fit an oil cooler?
Old 28-05-2016, 07:52 PM   #19
minisilverbullet
Some more of the head:
Pockets in the pistons:
ARP head studs in:
A marriage made in heaven! it really does feel liker the bled head was made for the a series.
Head torqued down and cams in
Old 29-05-2016, 10:22 AM   #20
minisilverbullet
I wondered if anyone knows the size of the 2 unions for the oil pipes on the rear of the cylinder head.
I could wait and call SC on Tuesday, but I want to try and make an order of parts tonight.
Old 30-05-2016, 10:57 AM   #21
gimenofl
gimenofl's Avatar
CC: 1380
ECU: Typhoon Specialist Co.
Excellent set-up, much better than mine with a dry deck. I cannot measure it tonight.
No oil cooler needed at least in my case, top pressure even in hot summer days.
Old 30-05-2016, 01:36 PM   #22
minisilverbullet
I found that the joints 3/8 BSP.
The pictures i have seen online show that everyone seems to use a 90 degree / elbow fitting, I guess there is no reason just to use a standard straight fitting.
Aslo I didn't specify that i wanted a dry deck, it came like this.
Old 30-05-2016, 08:21 PM   #23
minisilverbullet
Had a helper tonight:
Started mounting the throttle bodies:
Ram pipes
couldn't resist -
Old 31-05-2016, 12:30 PM   #24
cedric998
looks really awesome !!
rgds
chris
Old 31-05-2016, 07:44 PM   #25
minisilverbullet
cam/top plate on and cam pulleys on.
I had some trouble torquing up the cam bolts to 51 nm, since you need to hold the cam shaft with a ring spanner and the bolt with the torque wrench. I will need to get a mate in to help
Old 02-06-2016, 01:57 PM   #26
gimenofl
gimenofl's Avatar
CC: 1380
Seal that thing well Minisiverbullet. The cam plate likes to sweat as do the o-rings of the camshafts in case you plied them too much.
Old 02-06-2016, 08:57 PM   #27
minisilverbullet
The SC guide stated a 19mm spanner, it was actually a 18mm.
Any way while I was buying the spanner I bought a cam pulley holder, which meant i was able to do it myself.
Yip I have some RTV sealant in any place it may leak from .
Old 04-06-2016, 08:41 PM   #28
minisilverbullet
Cam bolts on torqued up now.
I am now thinking about which air filter to use.
individual cone filters will work, but then you can use the ram pipes.
So I am looking at domed foam panel filters from ITG and Pipercross (piper cross being half the price)
I know SC sell a domed ITG filter.
However, I am struggling with the throttle cable bracket, since it seems it will be in the way of most filters.
Old 05-06-2016, 07:24 PM   #29
minisilverbullet
Having a bit of trouble working out the wiring. In particularly the SPI really packs
I have them on the bench. Basically, it is a separate loom with the main black really box, one of the yellow relays and the connecter which sits beside the yellow really.
This loom had a couple of the old ECU sensors and a I guess a 12v feed.
All the old ECU parts have been cut off, leaving a wire from the main really for the O2 sensor and a wire from the yellow really for try O2 sensor. Can i just remove these from the relays? I assume this won't effect any thing thing else?
Old 05-06-2016, 08:44 PM   #30
gimenofl
gimenofl's Avatar
CC: 1380
Why do you need these? Just take all old sensors out and feed the Typhoon ECU as per spec? I am afraid I am not getting something?
