Old 25-02-2014, 11:28 AM   #1
Default my (dads) K1100 build ( Red Hot )
Hi All ,
Bought my dad a k1100 head for xmas , also the SC build Manual...
lost pictures of the head ,but most people know what they look like
anyway , dad just doing it in spare time and when he is bored , we had a spare 1275 A+ engine laying around so will use that as a base.
for now , he has got it stripped ,and has blocked off old stud holes in block.
still waiting for someone to send my dad me some long head studs (cough Ardonfast)
Old 26-02-2014, 01:49 AM   #2
I coughs so hard I woke up in your loverly sister
I've pulled them 4 long studs out of the ( a ) block they was new in 1992'
And when I sat rolling up a snought the smell of the fag was the same as that day, ile post tomorrow
Old 09-03-2014, 12:33 PM   #3
Dad created a tool for marking new stud centres , different bushes are required as holes in BMW head are different sizes, ( centre punch )
3mm pilot hole then drilled and then centre drilled to a diameter of .375
Centre drill stops larger drills from wondering , then drilled in steps of 1mm to 5/16 dia for tapping.
two more long studs required (ardonfast ! )
Head now slides over new stud positions a treat.
block now needs boring and onto next stage.
work out what to do about pistons now , make some , or buy some ?
Old 09-03-2014, 12:41 PM   #4
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
I've got 3 long studs in my hand. PM me your address.
Old 09-03-2014, 05:48 PM   #5
picture of head on block
Old 09-03-2014, 07:20 PM   #6
gimenofl
gimenofl's Avatar
CC: 1380
ECU: Typhoon Specialist Co.
Really nice, it's dry decked, right?
Old 09-03-2014, 07:22 PM   #7
I guess. Lol
Sent from my iPad using Tapatalk HD
Old 10-03-2014, 08:34 AM   #8
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Good grief you slag!
Sent from my HTC One using Tapatalk
Old 16-03-2014, 07:57 PM   #9
Got some honda st 1100 bike cam pulleys. Dad is going with them for now
First job to bore bottom pulley to 1 inch dia. Dad made tool to old it in lathe. Not wood pegs
Old 16-03-2014, 09:21 PM   #10
Kam
Kam's Avatar
Matt, how comes you want the cams chopped up? I can cut them down to 6ins?
I know nothing about these k1100 setups
Old 16-03-2014, 09:36 PM   #11
My dad only needs ends to make adaptors for Honda cam pulleys onto BMW cams Simpler to make if you allready have cam / locating slots etx.
Honda bike can pulleys are same as Honda car pulleys ( well mountings anyway )
Old 16-03-2014, 09:49 PM   #12
Kam
Kam's Avatar
Ahhh I see, no worries
Postman Pat will be processing them tomorrow...
Old 21-03-2014, 02:11 PM   #13
some cam pulley spacers made up for testing positions
and the honda st1100 bike cam pulleys in place , also he has made one fit onto mini cam, but needs a spacer etc made.
Old 21-03-2014, 02:53 PM   #14
cedric998
looks really good
have a closer look on the angle of grip for the cam belt. in you case case it looks rather small.
do these pulleys all come from the same engine ??
the 3 big ones look a bit too big for me. how many teeth do the big ones and the small one have ??
rgds
chris
edit
what did your dad use to close the holes in the block that are not used ??
Old 21-03-2014, 02:56 PM   #15
they do come from same engine , (Honda st1100 bike engine )
looking at other conversion pics , top pulleys have same gap..
Matt
