Old 19-08-2012, 05:19 PM   #16
deean89
CC: 1.8t
Need to do a lot of welding on the floors but I've just been offers a mini pickup :-s so tempted wot you guys recon pickups are miles cooler and I could mount my rad in the back haha
deean89 is offline   Reply With Quote
Old 19-08-2012, 06:02 PM   #17
I personally think it would be sacrilege to do this sort of conversion to a pick up or a mk1 and obviously ex works cars.
They're just so rare and I think that nothing should be done but original restorations to either of these.
Others will obviously disagree.
Old 19-08-2012, 07:15 PM   #18
Kaison
Kaison's Avatar
I can see where you're coming from, and somewhat agree.
But if he keeps the aesthetics reasonably original, then I think it's great that a car like this is kept on the road and enjoyed. - But that's my opinion.
I only bow under braking.
Old 19-08-2012, 08:06 PM   #19
adamb
adamb's Avatar
Id say grab the pickup if its a good price.
However the van is cool and you have done a lot of work already.
Depends if you want to start a fresh.
I'm sticking a 1.8 vvc rover in my pickup. Keeping standard roundnose and have some cool ideas in store.
Project mini VVC pickup :)
Build diary
Originally Posted by Kam View Post
With a mini track it will be like Jordan - seriously top heavy!
adamb is offline   Reply With Quote
Old 20-08-2012, 02:13 PM   #20
deean89
CC: 1.8t
if i do the pickup it will look like a standerd mini pickup + arches and 13 wheels i want it to look as standerd as possible will just be a little sleeper im gutted i have to lengthen the front end by 1 inch but not sure if it will be that noticable nyone got any pics of a mini with +1 metal front?
Old 20-08-2012, 02:59 PM   #21
Most fronts are extended 90mm, a 1 inch extension will barely be noticed, I wouldn't worry too much about it.
Old 20-08-2012, 04:42 PM   #22
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
The engine conversion looks good.
How can you expect a pickup to look standard with 13" wheels?
Old 21-08-2012, 08:17 PM   #23
deean89
CC: 1.8t
I mean not chopped up and stupid if you understand
Old 20-01-2015, 12:31 AM   #24
strudel
strudel's Avatar
Any more progress on this conversion? It looks like the intake was reversed after it was cut and shortened. does this have an impact as to how the throttle body mounts? JS
Austin Mini Van with DOHC Honda HP
http://www.angelfire.com/droid/strudel
Honda reliability and power combined with Mini cachet and style.
strudel is offline   Reply With Quote
Old 21-01-2015, 10:32 PM   #25
May be worth seeing if you can arrange the subframe for room for quattro to future proof it those engines could pretty comfortably overwhelm the front wheels of a mini
Old 20-02-2017, 12:47 PM   #26
robert_paull
How big is the 2.8 vr6 lump compared to the 1.8? And how much work extra would it be to add the 4x4 system?
robert_paull is offline   Reply With Quote
Old 21-02-2017, 01:11 PM   #27
M J W J
M J W J's Avatar
Considering this thread is from 2012 you are unlikely to get a reply. I assume this project was never finished.
My answer to the question would be 'a lot'. Fitting any none a series engine into a mini is a lot of work. There are off the shelf kits for a few engines but even these take considerable work.
No-one makes a kit for any VAG stuff so you would have to custom build everything.
If you haven't seen it take a look at project Binky on YouTube. It will give you some idea of the work involved in fitting a custom engine and 4wd system in a mini.
The few that have done on it on here have often used the floor pan and running gear from another car, shortened it and then fitted the mini shell over the top (see Hayling Mini's builds). Even the MiniTec Honda kit requires the floor to be cut and modified.
Old 21-02-2017, 02:20 PM   #28
robert_paull
Apologies I didn't even look at the date
I have a history of project builds, I have built a few and been involved with many more
Going right back to the late 90s but looking to get involved again
Old 09-08-2017, 08:08 PM   #29
Rob180bhp
More updates please.
Sent from my SM-G928F using Tapatalk
Rob180bhp is offline   Reply With Quote
Old 09-08-2017, 08:15 PM   #30
im with you never know he may have been in garage for 11 monthes
would be grate to see some thing, he last loged on this club 11 monthes ago!
