Old 16-08-2012, 09:23 AM   #1
deean89
CC: 1.8t
Default audi 1.8 20vt powerd mini van
hi guys ive been a member on this forum a while now but never posted anything just had a look around every now and again
hopfully this should be a good one
i have always been into my old vws ie mk1 golfs until i came across a old mini van shell for 600quid
it was abit of a basket case when i got it but i have done most of the welding on the shell now and its coming along nice
i had a 1.8 v5 turbo out or a audi that i had im my mk1 golf and after looking on here i realised that theres not many been done so i desided to have a go
i got hold of a old front subframe and cracked on with the plasma and pipe bender and ended up with this
the plan was to put it in a tsanderd length round nose but i will have to extend it by 1 inch
the subframe is about done just need to mount the bottom arms and tie bars
deean89 is offline   Reply With Quote
Old 16-08-2012, 09:52 AM   #2
Really like that subframe!
Engine fits there quite nicely, compact unit for what it is.
Welcome to the forum, will be keeping an eye on this one.
Plenty of pics and updates please!
Dan
Old 16-08-2012, 11:21 AM   #3
deean89
CC: 1.8t
Talking
cheers pal its very tight i no haha i had to cut a small square out of the passenger floor pan to get the diff housing in so now i will have to move the steering rack down a few inch
also to get the turbo in i got a stainless turbo manifold off ebay which the turbo should mount under it and cut it off at the plate that bolts to the engine and flipped it then welded it back on now i can top mount the turbo and not have to mess around with the bulk head
i was going to run the standerd ko3 turbo thats fitted to the engine but came across a subrau wrx turbo which is alot bigger to ger it to clear the rocker cover i will need to make a spacer anyway so just going to put a flange on the top to take the scooby turbo
im running a mk4 golf 1.9tdi gear box for longer gear ratio and engine should be around 300bhp
i got a inlet manifold onn a audi tt bam engine which has the throttle body at the other end and shortend the intake pipes by 3 inch and had it tigd back up now it fits great in the mini front end also now i cam mount my intercooler on top of the gear box and the pipe work will be a peace of cake 90 off turbo and straght off throttle body into intercooler with a nice big dump valve along the way
Old 16-08-2012, 11:32 AM   #4
deean89
CC: 1.8t
sortend and ported inlet manifold
running a big port head so had to diegrind inlet manifold to suit
Old 16-08-2012, 11:53 AM   #5
Phaeton
Phaeton's Avatar
Probably being very silly here, but how can a V5 only have 4 inlets???
Alan...
Old 16-08-2012, 12:21 PM   #6
Thats because a V5 is a confused little engine.
Old 16-08-2012, 02:03 PM   #7
deean89
CC: 1.8t
little engine big power its a 20 valve 5 valves in each port mate
Old 16-08-2012, 03:18 PM   #8
deean89
CC: 1.8t
Old 16-08-2012, 03:23 PM   #9
deean89
CC: 1.8t
rear beam im making
Old 16-08-2012, 03:28 PM   #10
Significant size difference between the 2 blowers.
Which Subaru turbo is it? TD0?
Old 16-08-2012, 03:30 PM   #11
Kaison
Kaison's Avatar
I assume the size difference is because the Subaru is designed to output 270 odd as standard, while the VW KO3 is 150 odd
I only bow under braking.
Old 16-08-2012, 03:35 PM   #12
deean89
CC: 1.8t
yer its a tdo mate lots of vw lads use them its a poor mans gt28rs haha
Old 18-08-2012, 02:45 PM   #13
DVO
DVO's Avatar
ECU: Chipped
Very nice build and really something different. But where are you going to put the radiator?
Dennis
Old 18-08-2012, 06:28 PM   #14
deean89
CC: 1.8t
Dennis
Haha not sure yet mate might put it in the back I'll find somewere
Old 18-08-2012, 07:27 PM   #15
That's what roof racks are for!
