Old 01-04-2018, 03:03 PM   #76
steve w
Make: Ford
ECU: Specialist Components Typhoon
Bootlid fitted.
Shape of the fibreglass isnít great, but it will do for now
This is FORD country....on a quiet day you can hear Vauxhalls rusting.
If at first you dont succeed, Destroy all evidence that you ever tried
steve w is offline   Reply With Quote
Old 12-05-2018, 06:26 AM   #77
steve w
Make: Ford
Been waiting ages for 1 chargecooler rad to be made, and 2 turn up at once!
Turns out there was an issue at the fabricators, and the 1st was made too small. So now I have to work out what to do with the 2nd one ��
The correct one fits perfectly. Both outlets on the LHS, with a bleed on the other. It’s the exact dimensions of the grill opening, and fits between the end tanks of the Focus rad
Final plumbing from the pump to the rad to run next, then that’s the last of the big stuff.
Currently wiring in the lights, then it’s wipers, reverse light, and fog light.
Old 13-05-2018, 09:11 AM   #78
Muffyvaux
Muffyvaux's Avatar
Looks amazing as always.
Who do you use to make your rad. I'm going to need a pair similar for my race car and also a custom intercooler.
Ben
Old 13-05-2018, 05:53 PM   #79
steve w
Make: Ford
I used ADR at Silverstone , top quality work
Ben
Old 20-05-2018, 07:16 PM   #80
steve w
Make: Ford
Bit of an update from today
A-panels are bonded on, so is the door skin.
Doors fitted
Steering column had to be refitted as the steering wheel was off centre.
Few other bits
https://youtu.be/BeYW0bGMRF8
Old 21-05-2018, 06:35 AM   #81
Good vid ,sounds lively! Glad to hear about bonding, it's the way ahead!!
Whats with steering wheel off sentre ?
Old 21-05-2018, 10:37 AM   #82
steve w
Make: Ford
They have to be bonded, they’re carbon!
Just that when I fitted the column after welding on the the quick release boss, I didn’t have the splines lined up
Old 16-06-2018, 05:42 PM   #83
steve w
Make: Ford
Been contemplating how to mount the additional radiator, and came up with this solution
The main rad has a u-section channel on top
So made a right angled bracket with a return on it. Used high temp silicone to attach it
Fairly happy with the fit.
Old 24-07-2018, 06:19 PM   #84
steve w
Make: Ford
Fitted the bonnet catches and here’s the result
https://youtu.be/rnZxlTba-bU
650g all in, is about as light for the road as I’d go.
I’ve made lighter, but this seems usable
Old 24-07-2018, 08:42 PM   #85
evenbiggerdave
Thatís super cool
Dave
evenbiggerdave is offline   Reply With Quote
Old 29-07-2018, 10:34 AM   #86
That's ok ,seems to return, road test will tell ,
Are you tempted to bond a strip of silant coat pad under ?
