Old 10-06-2011, 08:47 PM   #1
steve w
Make: Ford
ECU: Specialist Components Typhoon
Default Rwd Zetec Mini - now Duratec Rs Turbo
Already posted some pics of the car (and thought about selling it more than once!) But thought I'd put them into a build diary now, as Ive re-ignited the build!
It is a 2.0l Zetec Blacktop engine, fitted with a Tubular exhaust manifold, K&N, and Typhoon management.
The front end has a Cox gtm fuel tank, converted for fuel injection. Focus Alloy cored Radiator, and header tank
Ive gone for KAD 4 pot front brakes with vented discs and KAD pedal box.
Although these are soon going to be switched in favour of a home made willwood/KAD/custom disc setup
a few pics
Front end 1 part of a carbon 2 piece front, with a Prepreg carbon Mk1 Bonnet
A-panels are also Prepreg Carbon, Roof is Fibreglass, as is Bootlid.
I cut the inside out of the doors and have fitted slightly tinted Perspex windows
Wheels are now Force Racing 3 piece split rims, in black (The only Significant part of the car that isnt Second hand I think!)
This week Ive just finished converting a set of Pulsar GTIR ITB's to fit the Inlet side of the Zetec head, all going according to plan tomorrow, I'll post some pics up Monday!
This is FORD country....on a quiet day you can hear Vauxhalls rusting.
If at first you dont succeed, Destroy all evidence that you ever tried
steve w is offline   Reply With Quote
Old 10-06-2011, 09:35 PM   #2
philster
philster's Avatar
ECU: Megajolt + bikecarbs
we need pics with the bonnet off!
just read again, is it mid engined? still need pics
philster is offline   Reply With Quote
Old 10-06-2011, 09:54 PM   #3
steve w
Make: Ford
Old 10-06-2011, 10:35 PM   #4
kcchan
kcchan's Avatar
I remember reading build diaries for this but they disappeared? Lots of carbon I seem to remember.
Suck, Squeeze, Bang, Blow.
Old 10-06-2011, 10:58 PM   #5
miron
rwd mid engine is the way to go!
miron is offline   Reply With Quote
Old 17-06-2011, 07:15 PM   #6
steve w
Make: Ford
throttle body adaptor plate finished. fitted it with mini wheel studs, countersunk from the rear.
Got these twin throttle bodies from a Nissan Sunny GTIR
had to mod them slightly with a bandsaw, to make them sit slightly closer together.
and this is them together
Just got to mod the injector rail, and port the adaptor plate slightly (5mm in width per port) to match the sunny and zetec spacings
Then need to make up a trumpet and clamp plate, and there you go, a 50 46mm itb conversion!
Old 28-06-2011, 06:26 PM   #7
steve w
Make: Ford
Got a bit of work done.
painted the roof, seems to have come out very flat, think it may have been far too hot yesterday.
Colour is a bit bright, but im blaming my brother-in-law as it was his idea!
Also switched the high pressure side of the fuel line to braided hose. Although it was already high pressure injection hose, figured it was best to make sure.
Thought it was best to do alot of pre-fitting on the front, as its just not sitting right, and is pushing the rad back towards the tank one side. Finally got round to bonding the arches on with carbon fibre aswell.
Got the old driveshafts out today, new ones are in progress, but im having to get the snapped ones repaired before Avon.
Old 17-12-2011, 02:09 PM   #8
steve w
Make: Ford
Been a while since the last update.
I've been arranging a new engine, and the focus Rs engine has just arrived.
I have a Primary Designs manifold on it's way, aswell as a hybrid Gt25 turbo. All this should see me with around 315-330 bhp.
Hoping to get it in by February, and get it mapped before the good weather arrives, so I can get testing when the weather allows.
Old 17-12-2011, 02:15 PM   #9
philster
philster's Avatar
That's gonna shift! is it the T5 engine or the eariler ford variety?
Old 17-12-2011, 03:22 PM   #10
steve w
Make: Ford
The earlier, it's basically a renamed, low comp, zetec with a reworked head!
Old 18-12-2011, 11:58 AM   #11
matt
matt's Avatar
ECU: Mems 3 Z&F
Looks good.
How does it handle is it predictable? Bad understeer, oversteer?
Rover no show and all go!!!!!
Old 18-12-2011, 03:48 PM   #12
steve w
Make: Ford
Originally Posted by matt View Post
Looks good.
To be honest, not too sure yet! It went really well in straight line with 140bhp. Well, when I didn't have snapped driveshafts, or had messed up the map! Which has meant I haven't even managed a complete run up the strip yet. Spent money in the right places this year, so will find out as soon as the snow leaves us!
Old 19-12-2011, 12:53 PM   #13
caveman
caveman's Avatar
CC: 2.1
ECU: dta
Send a message via Yahoo to caveman
Coulor looks great mate be nice too see the red roof flying down the strip
anymore projects and im a dead man so the wife say,s
caveman is offline   Reply With Quote
Old 19-12-2011, 03:59 PM   #14
kcchan
kcchan's Avatar
The red roof might help spectators keep track of it!
Old 14-02-2012, 12:22 AM   #15
miron
any progress steve??
