Old 12-06-2017, 10:22 PM   #16
Basil
CC: 1598
So front end is now all lined up, is bolted on front panel, wings and will also attach to inner wing.
This is the other side before it was bolted on, nothing moved when we took all the clamps off
We made some braces for the a panels, not everyone does this but as the steel front end is a little heavier its worth doing. Also its not going to be too stiff? will be plug welded, had ran out of weld through primer.
They are in line the photo is wonky, also you can just about see the harness bar in the back
Finally whilst the rear subframe was off got it and the radius arms all painted up.
Next job is brace bars and try and tidy up the engine bay a little.
Old 18-08-2017, 03:17 PM   #17
Basil
CC: 1598
Boot all stone chipped, will also do rear bench
Roll cage plates welded in, apparently the ones in the bins were a real pain
Roof chopped out and new skin in place
Brace bars all made up
Brace bars in place and engine nice and green, cam cover is in black crinkle effect. Will be wrapping the exhaust manifold.
Old 02-10-2017, 10:37 AM   #18
Basil
CC: 1598
Interior, wheel arches and inside boot are now all painted, pictures are a little dark so don't quite show the colour
Just when we thought it was finally 100% rust free, a small patch was found when taking the shell back to bare metal, it has now been sorted. Note the last picture, is before any filler had been applied.
here's how it stood, put the front end back on as it made sanding a lot easier,
Old 02-10-2017, 10:46 AM   #19
Basil
CC: 1598
Again the pictures really don't do the colour justice, it's a lot more blue in real life. The colour is Speedwell Blue.
Old 08-10-2017, 05:29 PM   #20
Basil
CC: 1598
Wheeled it outside to make room to work on the rest of the parts
Can see underneath the fibreglass roof, has a pretty cool texture to it.
Paint has good shine to already, this before any cutting back and finishing has been done, just how it dried after paint. Is 1 coat acid etch, about 3 high build primer and about 5 of topcoat all in cellulose. Etch is from Clostermans primer and topcoat from Nu Agane.
Everything else is prepped pretty much. Doors needed a little filler as the previous owner did the door skins. Also the wings needed some firstly from the adjustments to get it to all line up, and also one had very slight crease, that wasn't noticeable until it was down to bare metal, still took forever to sort.
All the time spent lining up the front end and all the time spent on prep and carefull minimal filler, the car should look very straight.
This is all now in primer
Finally stuck a bit of silent coat in as most of the sound deadening had been removed to repair the floors previously. Didn't have one of those fancy roller things so used a skateboard wheel. And yes, those are my socks , it's a shoes off kind of job especially because there are a couple of bits of interior paint that need touching up so it helps with the dust/dirt!
The seat mounts are still on the cross member because someone has welded them to it, not sure why.
Old 10-10-2017, 08:55 PM   #21
Basil
CC: 1598
Here's a door with one coat of paint on it
Stonechipped the edges of the doors, has come out well
All the structure on the underneath of the bonnet has been removed, is not needed as it will be on pins, is quite bendy though.
The inside of the front end is all stonechipped, you can see the work done to the front mounts to make it removeable, also the notch to make room for the exhaust, I have some of that gold reflective heat tape to go on it, should stop the paint from getting cooked.
Old 15-10-2017, 07:45 PM   #22
Basil
CC: 1598
Quick update everything is now painted, not long to go now!
Cage is a Safety Devices one from Minispares, the harness bar is from Jon Betts (great guy, very helpful)
Also have tidied up the front subframe, was quite rough before. Brace bars now painted and fitted.
Went to put the new brakes on (old ones for sale if anyone is interested), unions were no good so needed replacing. Brake lines and Clutch lines were not the best a bit kinked in places, all hand bent and not particularly secure. So new unions and some nicely bent lines with a proper tool will be fitted. Exhaust manifold is now wrapped.
Old 17-10-2017, 10:06 PM   #23
Basil
CC: 1598
The new rad mount it now done.
These end sections are made up from folded steel, with swaged holes, they sit over each end and bolt into the existing mounts on the rad. The rad is an alloy mpi rad, which is thicker than standard so cools better but is much more of a pain to fit! The brace bars needed modifying.
It mounts onto the brace bar like this, there is also another mount on the front crossbar on the subframe.
Is all very snug but fits fine with good clearance all round
New wheels are on and it is really starting to come together!
And finally got the bracket for the bonnet pins and springs on, using little cap heads, looks a lot nicer than self taping screws or rivets.
Old 18-10-2017, 04:41 AM   #24
Very, very nice. Looks so different with the 10" wheels
Old 22-10-2017, 12:37 AM   #25
Basil
CC: 1598
Couple more of the rad
Offering up the new boot lid, fits surprisingly well for a single skin fibreglass boot
The boot is secured by two springs and no lock, these springs normally scratch the paint which is not normally an issue on a track car. Sometimes people put electrical tape under them to stop this, I thought I'd use blue tape as it would match better but then decided to get some vinyl sheet to stick on .
Boot all finished and with plate stuck on
Finally fitted some over riders, but I am not sure about the fit, they look like they are slanting forward but its as vertical as we could get them
Also trimmed the end off the exhaust, it stuck out quite far and had a rolled tip, this is a little more subtle.
Old 22-10-2017, 08:33 PM   #26
player14
Send a message via MSN to player14
Great progress. What way have you mounted your alternator?
www.eastcoastminis.org.uk
player14 is offline   Reply With Quote
Old 24-10-2017, 08:13 PM   #27
Basil
CC: 1598
Currently a suzuki alternator fitted round the back on what i think is a bracket from Allspeed, I don't think they sell them anymore but you might be able to get something similar for a Nova as people need to lower the alternator when fitting Webers. Mine is on the wonk though so will be doing something to straighten it out, can hopefully alter the existing bracket, watch this space.
Old 25-10-2017, 01:19 PM   #28
player14
Would you have any pics of it in place? Do you know the model number of the alternator you are using?
Old 28-10-2017, 06:12 PM   #29
Basil
CC: 1598
Is off the car at the moment will post why in my next update, model number is ALT30204 some details, alternate parts numbers and cars it can be found on are all here. I will post pics when it is back on the car.
Old 28-10-2017, 06:31 PM   #30
Basil
CC: 1598
Went to finish plumbing in the rad and a piece of the old rear rad pipe broke off
Will plumb it back in with aluminium and stainless tube, and silicone bends.
Had to take the inlet off to get access to it, which was held on with these “bolts”
Some of the brake lines needed replacing anyway, and most were not pretty
Whilst the inlet was off, thought it would be a good chance to get the bulkhead all sprayed up and tidy the wiring, the first step, pull all the spaghetti the though the bulkhead
After bare metaling the bulkhead, stone chipping and painting it looks like the pics below.
Also split the loom in two so the majority can run behind the dash, It can now exit the bulkhead on both sides tidying up the engine bay. Is all wrapped in tesa loom tape which I highly recommend.
sorted all the dodgey wiring, extended some, chopped out some and some had to be replaced.
The new brake lines and clutch lines are also mostly run, the orange clutch hose is for a BMW Z3.
Also touched up the engine paint.
Next step is to fix the alternator bracket as the current one sits a little crooked.
