Old 09-07-2017, 07:08 PM   #61
Richie13
CC: 2ltr 8
Started on passenger side rear arch today spent a lot of time measuring up to make sure it's the same as the driver side as the arches are the only two panels that are aftermarket panels all spot welded on seams and just need to finish of outer arch lip
Richie13 is offline   Reply With Quote
Old 26-07-2017, 10:36 PM   #62
Richie13
CC: 2ltr 8
So the rear arches are coming on slowly so the passenge side is almost finish but will finish of when I do the whole body and the driver side nearly finish as well
Old 30-07-2017, 07:07 PM   #63
Richie13
CC: 2ltr 8
Driver side nearly all done now and the rear wheel bearings are done now as well
