Old 12-09-2012, 03:32 PM   #16
matt skidd
matt skidd's Avatar
ECU: Omex
Default chop chop chop
[IMG][/IMG]
matt skidd is offline   Reply With Quote
Old 12-09-2012, 03:34 PM   #17
matt skidd
matt skidd's Avatar
ECU: Omex
Default space for the shifter
[IMG][/IMG]
Old 12-09-2012, 03:35 PM   #18
matt skidd
matt skidd's Avatar
ECU: Omex
Default steel work going in foe weber space
[IMG][/IMG]
Old 12-09-2012, 03:36 PM   #19
matt skidd
matt skidd's Avatar
ECU: Omex
[IMG][/IMG]
Old 12-09-2012, 03:40 PM   #20
matt skidd
matt skidd's Avatar
ECU: Omex
Default frame back on and box in to check the shifter box
[IMG][/IMG]
Old 12-09-2012, 03:43 PM   #21
matt skidd
matt skidd's Avatar
ECU: Omex
from doing this i can defo say when you get to this point order a gearbox seal kit cuz they all leak
Old 12-09-2012, 03:45 PM   #22
matt skidd
matt skidd's Avatar
ECU: Omex
Default time for a little paint
[IMG][/IMG]
Old 12-09-2012, 03:46 PM   #23
matt skidd
matt skidd's Avatar
ECU: Omex
[IMG][/IMG]
Old 12-09-2012, 03:47 PM   #24
matt skidd
matt skidd's Avatar
ECU: Omex
i have lost a load of pick of my build
Old 12-09-2012, 03:50 PM   #25
matt skidd
matt skidd's Avatar
ECU: Omex
Default tubbing rear arches with a single piece of steel was tricky but worth it
[IMG][/IMG]
Old 12-09-2012, 03:52 PM   #26
matt skidd
matt skidd's Avatar
ECU: Omex
[IMG][/IMG]
Old 12-09-2012, 03:53 PM   #27
matt skidd
matt skidd's Avatar
ECU: Omex
Default frame re instaled
[IMG][/IMG]
Old 12-09-2012, 03:59 PM   #28
matt skidd
matt skidd's Avatar
ECU: Omex
Default engine back in with my custom manifold i made and the H&H ignition system fitted
[IMG][/IMG]
it took alot of work to get this far but felt like i getting there
Old 12-09-2012, 04:01 PM   #29
matt skidd
matt skidd's Avatar
ECU: Omex
Default Denso going on with some custon brackets
[IMG][/IMG]
Old 12-09-2012, 04:03 PM   #30
matt skidd
matt skidd's Avatar
ECU: Omex
[IMG][/IMG]
