Old 27-02-2011, 08:10 PM   #1
benh
benh's Avatar
Default Carbon lightweight E16SE Road Toy
New build thread for my vaux project.
Hoping to get it finished towards the back end of the year.
Right then,
We start here, although the car looks finished the rust was starting to come through, seam strips,boot hinge panel and under the rear lights were starting to bubble, so time to attack it before it gets worse
Boot was also in a sorry state. Decided that il go with a fibre one this time.
Also the webasto roof (the 2nd one in 2 years) was showing signs of shrinking around the eges so this will be replaced with a carbon roofskin
Will be updating more tonight
benh is offline   Reply With Quote
Old 27-02-2011, 08:47 PM   #2
benh
benh's Avatar
So then How did i get from that to deciding on a vaux build!
Managed to get 6 points in my first 2 years of driving so had my licence revoked,
Id spent 2 months off the road and it was painfull.
Managed to get back on the road but i just didnt like the car, it was heavy, full of filler where the scuttle meets the wings which was cracking and lifting, the engine was fine but it was messy, messy wiring messy looking etc
Id always wanted a fibreglass frontend so i decided to take it off the road for a month
So chopping began,
I have more pictures of the engine but tbh i want to try and keep the a series stuff out of it as there was a seperate build page for it.
You can see the filler in most of these pictures, it was almost held together with it rather than welds!
So while the engine was out i decided to send it away to have it bored out.
Started at a few hundred on a rebore and turned into a complete fast road 1330 costing a couple of thousand!
Old 27-02-2011, 09:22 PM   #3
benh
benh's Avatar
Engine came back almost a year later, dont ask!
didnt even make the journey home and it went straight to a garage to be told it was a scrap engine.
Money refunded and having a slightly healthy bank account i went throught my options
standard 1275 and keep the change pay bills etc
another 1330/1430
supercharged 1275
or a vaux conversion
Id always wanted a vaux conversion but 2 years ago i couldnt do anything with cars! so id chickened out! But with 2 years of tinkering and a stroke of luck as when my refund came through a full small block setup was for sale on here with literally everything with it including 2 engines a perfect E16se and a sorry looking c16se
soo...
Weighed up my options and decided to flog the servo bar and stick with the better condition E16se.
Quick cambelt and water pump change just for piece of mind and a paintjob and ready for dropping in. Minus a decent cam/head and carbs but they will be come later.
Old 27-02-2011, 10:27 PM   #4
benh
benh's Avatar
Picked up my conversion bits and obv the first thing anyone wants to do is see if it all fits!
On with progress!
Old Subframe gone
Frame offered up
Then Painted before fitting
Wollah
Trial fiited the servo but decided to bin that idea and run a pedal box without a servo
Old 27-02-2011, 10:43 PM   #5
benh
benh's Avatar
Nice order of lightweight panels to start work on the rear end, Decided to go with a carbon rear valance but havnt got a picture
Old 27-02-2011, 10:59 PM   #6
benh
benh's Avatar
Right bought myself a welder and compressor fun now begins but need to learn how to weld and spray so practice practice practice !out with the grinder and out with the parcel shelf, Will be replaced with a carbonweazel shelf.
was a bit of flex so decided to weld a bar in place until the shelfs fitted
Off with the valance and rear lip, replacing with Carbon again
Then needed a repair section in the boot corner and under both rear lights
started prepping
Old 27-02-2011, 11:03 PM   #7
benh
benh's Avatar
Have done loads more work but will update tommorow as its late but look what i have to play with tommorow may even have a go at getting it running!
Old 28-02-2011, 04:09 AM   #8
Add_Gee
Add_Gee's Avatar
ECU: Rover
I like the colour scheme! coming along well
Old 28-02-2011, 11:05 PM   #9
benh
benh's Avatar
Thanks Mate,
Boot floor cut out for the new fibre one to go in, regretted not going carbon weave tbh but hey ho!
Then boot hinge holes welded up and bonnet pin corner pieces welded in place to be trimmed down later
Then onto prepping the rear end
Bonnet pin corner pieces trimmed down
Old 28-02-2011, 11:12 PM   #10
benh
benh's Avatar
Pretty much finished now and ready for paint, although i made a decision to tub the arches after all of this!
Used Barcoat as i was having problems with reactions and it leaves a nice big fat coat
Old 28-02-2011, 11:13 PM   #11
Burnard
Burnard's Avatar
Looking good ben, when are you planning to get it done by?
One thing i noticed, is that a show plate, or your actual plate?
If its an actual plate, you do know its not legal?
Old 01-03-2011, 09:13 AM   #12
benh
benh's Avatar
I want it done by the end of the summer!
Its my real plate but obviously the spacings not legal.
Should be B7 ENH. Might change it before its goes back on the road but it hadnt caused any problems before but only takes one copper i know!
Old 01-03-2011, 11:12 AM   #13
Burnard
Burnard's Avatar
Thing is, you can probably get away with it if everything else about the plate it legal due to the templates that are used, which are 4with a standard space then big space, then 3 with standard space. Which is what they seem to have used with yours.
If everything else with those plates it perfectly legal, i recon you will get away with it, or just get a producer as you can say you didn't realise.
Totally different to these people who have more than one big space, or a huge space between 2 letters. At least yours does follow the legal spacing, its not in the right place
Have you got any close up pics of how your front end is attached to the subframe at the front?
Old 01-03-2011, 08:53 PM   #14
benh
benh's Avatar
Sound system removed which weighed in at a hefty 80kg, just a few kg over what i weigh so its a massive saving! Too chavy for my liking!
Then rear bench cut down and rear bins removed/nice bit of rust along the way!
Old 01-03-2011, 09:07 PM   #15
Hayling mini
Hayling mini's Avatar
CC: 1340
ECU: Haltech
Looking really good Ben, well done
