Old 20-12-2017, 07:41 PM   #136
will16
will16's Avatar
ECU: K Maps 170
Been neglecting the car recently, been running spot on though! Did a slippy track session at silverstone for Trax back in October and the cars sat since. I've got a big list of things to do over winter, I'd like a 13s 1/4, so I built up a C7 box with a torsen, this is my 2nd attempt at building a pg1 but it went together alot smoother so I'm hoping it will be gravy!
I wanted to sort out something thats been bugging me, the engines always sat on the p!ss, this is due to me overcompensating for how much I thought the Rover engine mount would sag, this also meant the passenger side driveshaft cv gaiter rubbed on the frame rail, nice and messy Stripped the car down and redrilled the gearbox mount side today, will bring the welder home and put some strengthening plates on it
Can see how wonky it was here
Made sure the car was level
Leveled
Drilled
Front still fits, just! Cam cover needed some clearancing
Gaiter has way more clearance now, was touching frame rail before
Been having some fun with this in the mean while
will16 is offline   Reply With Quote
Old 13-01-2018, 04:01 PM   #137
will16
will16's Avatar
ECU: K Maps 170
With moving the engine, it altered my engine position so that the rear engine steady didnt fit. With some advice off here I made a new one using a series polybush's and tube and modified the solid rose joint front steady to make it less harsh. Then the engine could come out for the gearbox change and I wanted to tidy up the bay a bit as I wasnt keen on it as it was very cluttered and 'thrown in'. I'm not going for a full shaved bay, the engines been in and out more times than I can remember now so properly tucking everything would be a nightmare! The wiper motor got moved behind the bulkhead, a lot of the wiring was simple to do and unplugged and replugged behind the dash. Also I copied what Gaz has done and got rid of the inner wing braces and boxed the ends in, made some dimple dies at work so put them to use The bay got a colour change too, I wish Iíd spent a little more time to prep the bay and get it really smooth, but Iím happy with how its come out for a rattle can job
Plated round the old hole
Exhaust flexi and gearbox have been rubbed a little
Wiper motor
Start of the bay
garage set up
How the bay came out, its shinier than it looks
Old 13-01-2018, 07:37 PM   #138
I like the dimple holes, looks very neat
gazwad is online now   Reply With Quote
Old 13-01-2018, 08:49 PM   #139
How are you going to stop the gap between your new strengtheners and the original inner wing filling up with water and crud?
Old 13-01-2018, 09:26 PM   #140
Love the dimple die!
Chris16v is online now   Reply With Quote
Old 14-01-2018, 05:13 PM   #141
will16
will16's Avatar
ECU: K Maps 170
Thanks guy, appreciate it Tbh I hadnt thought about them filling up, I'm going to cavity wax them and probably drill a drain hole
Made a start on the metal front end. Now if your thinking Iíve made it hard for myself using the original passenger wing and part of the front panel and wondering why Iíve done it like that, so did I once I had started Worked out ok in the end, still needs finishing off but I was nursing a hangover. Also put some stuff back in the bay, bought a nice owens motorsport expansion bottle. The normal rover plastic tank cap opens at 1 bar, I went for a 15 lbs mini cap which is a close value. Thats everything in the bay that will be there, apart from the ecu. Also sprayed the subframe ends black, Iím trying to hide the conversion a bit
Old 15-01-2018, 03:04 PM   #142
asahartz
Personally I wouldn't have used that polybush - my 1275 A-series shredded one in a fairly short time and I went back to rubber which has a bit more give.
asahartz is offline   Reply With Quote
