Old 28-07-2008, 09:06 PM   #61
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
Send a message via MSN to GRIFF2494
Default THE SPIT FRAME
since learning to weld again (with gas now ) ive started to remove the other sies inner sill, was going to just patch it,but i may as well do a proper job!!!!! esp since once done i dont want to do it again i a years time lol
this is the reason why i decided in the end to replace the lot !!!!
chopped thefront halfout
will chop rst out tommorow and then hope fuly fit the inner and outer sill back in as ive got a DAY OFF WORK
GRIFF2494 is offline   Reply With Quote
Old 29-07-2008, 06:46 PM   #62
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
well had my dayoff work so carried on cutting out the sill (once i finally got out of bed lol )
it turned out to be a right twat to remove
Old 29-07-2008, 06:50 PM   #63
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
but fitting the inner sill was even worse !!!!!!!!!!!!!!!!!!!!!!
but finally managed it
Old 29-07-2008, 06:55 PM   #64
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
Default t
then i had to try make the outer sill fit
again like the inner sill,the outer was a twat!!!!!!!!!!!!
but now both inner and outer sills have been completly removed and replaced
so hope fully will never need to go down this road again
just need to but seam sealant along the new joints :-
Old 08-08-2008, 03:55 PM   #65
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
Default t
well been a week or so now since i did anywork on the car been 2 busy at work
but now im on holiday from work for 3 weeks
so should be able to get lots done!!!!
started to cut metal to make mynew flat boot floor today ,not got very far with it as it rained
weel as u can see infact all i did was draw round a repair panel i have and welded abit of metal to it lol
well me and my good mate DAZ (never forget to include the friends that help u from time to time with builds !)
are going to scrap yard tom to get a complete metro 100 front subframe with running gear all for 50 so happy with that
then i canrealy start getting on with the build
Old 10-08-2008, 05:51 PM   #66
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
well here is the donar metro lol
after a few hrs of hard graft trying to get thr sub/engine free DAZ decided it was time for a break lol
then it was time to take the subframe,etc to the car
sounds easy but seeing the donar car was at the far corner of the yard it was back braking work
Old 10-08-2008, 05:55 PM   #67
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
Default t
once home it was time to see wot i had got lol
and hopefully this will fit
ALL FOR 50 IM WELL HAPPY AT THAT !!!!! much cheaper than buying the watson frame like i was going to !!!!! will just replace allthe rubbers, still 100 ssss cheaper
Old 10-08-2008, 06:01 PM   #68
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
Default t
then it was time to steam clean the parts
but when i took them the steam cleaning place was shut
so i had to get the trusty power washer out to try and remove most of the bananas !
not got it all off, but looks much better now, want take much more cleaning
then once most the bananas was removed i found a serial number on top of the box under the pineapple,
anyone no wot this number tells ????
Old 10-08-2008, 06:07 PM   #69
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
typical !!!!!!!!!! was cleaning then the skys turned black and the skies opened !!!! it grapesed it down !!!!!
once stopped i totaly stripped the subframe so i could have a look if any areas needed atention
and it does not just a lick of paint !
Old 10-08-2008, 06:42 PM   #70
5c35 gearbox, best one you can get for a mini, got the tallest final drive out all the R65 gearboxes
Old 10-08-2008, 07:51 PM   #71
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
Default t
cool !!!!!!!!!!!!!!!!1
that was a stroke of LUCK
i followed MATT instructions he said look for a 1.1 with less than 50000 miles
i looked at lots in the scap yard then noticed that most of them either had 80 000 + mles or only had 4 gears !!!!
then i found this one ,5 gears 39 000 miles!!!!!
glad u told me i got right one after the effort it took me and my mate DAZ to get it out, i would have been so grapesed if it was wrong one
cheers for your reply EVOLUTION
griff
Old 10-08-2008, 07:59 PM   #72
matt
matt's Avatar
ECU: Mems 3 Z&F
Im pretty sure that flywheel wont work . You need to try and find a 1.6 flywheel from a car that had mpi injection. But first you are best to take the flywheel out of your vvc and we can try and find out exactly what flywheel you will need. A 1.6 flywheel will be best because the bigger cluth will bolt on to it.
It shouldnt cost alot but will be hard to find one.
Rover no show and all go!!!!!
Old 10-08-2008, 08:10 PM   #73
dazlee
cheers MATT that means more time in the scrap yard lol
dazlee is offline   Reply With Quote
Old 10-08-2008, 08:39 PM   #74
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
Default t
thanks for your reply MATT
i cant check yet as im using my donar car as a work car right now while ive been doing the body work on the mini
now i have the frame i will prob be taking the vvc off the road to start the conversion (have to bike to work) will send u soe pics then as u wll prob n if it will work
as for u daz YES your right looks like we willbe having a day out in the scrap yard again !!!!!!
griff
Old 10-08-2008, 09:01 PM   #75
matt
matt's Avatar
ECU: Mems 3 Z&F
looking on metro power and you will need a flywheel from a r65u which was used in rover 416 and a 216. These flywheels are 4 pole flywheels but im not sure but it may be possible to use any mpi twincam engine flywheels from the old k series engines (before they went to mems 3 ecus).
http://www.metropower.co.uk/forum/fo...44337&posts=14
