Old 07-07-2008, 08:54 PM   #46
spNOam
spNOam's Avatar
ECU: Tweaked DTA
Stop welding after 1.5 sec & start again for 1.5 sec etc etc leaving the metal to cool a bit between stops & starts, with a bit of practice you can produce some nice runs with good penetration.
To insanity & beyond!!
Geoff
Old 08-07-2008, 08:06 PM   #47
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
Send a message via MSN to GRIFF2494
Default THE SPIT FRAME
thanks for your help spNOam
ive followed wot u said and it worked a treat
as u see its taken well, tomorrow i just need to grind some parts back abite ,once panted imsure it will look sweet
as for penetration as u see below its def done that
next i need to fit the new outer sill would i be best to waxonol the inner sill first or will it burn when welding the new outer sill???? i could all ways spray some in after throw the inspection holes??????
GRIFF2494 is offline   Reply With Quote
Old 09-07-2008, 07:34 AM   #48
ludsonline
ludsonline's Avatar
CC: 3000
Make: Ford
Project looking really good m8.
You should be ok with waxoyl in there. When I did mine I sprayed it all with weld through primer then masked up the areas where I was going to weld and applied two good layers of top coat then waxoyl and then welded the sill on.
Ford Corsair 1966 3.0 V6
ludsonline is offline   Reply With Quote
Old 09-07-2008, 09:26 AM   #49
bhphunter
bhphunter's Avatar
Id give it all some paint first then squirt waxoil in the holes once welded up. Remember that the black paint on panels is a 'transport' paint and should really be rubbed down prior to paint.
Ive had some panels where it has been applied well and others where it has scratched off with my finger nail
build diary
Old 11-07-2008, 08:39 PM   #50
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
well i took your advice ludsonline
and went shopping for some weld throw primer ( melons me it exspensive , wel the wife thought so anyway lol )
as u can see from the above pics ive primed the out side of the inner sill and also along the seam on the inside of the car
next i tested the outer sill for fit, had to go with the dreaded over sills else u would see the join where the new inner sill joins with the floor (but at least seeing ive put them on my self i no there not on over a rusty old sill like they normaly are :- ) ) i must admit NOT the best fit
but once the hammer came out and a bit of reshapng they fit snug
had to do the same as with the iner sill as i still have no spot welde to had to pool weld it on but theres no way it will come off lol
once on i went rond with the other product i got today ,some seam selant
ran over it with some water to try and get a semi smooth finish
(the lumps in the pic are just thewater )
heres the finished look from out side
for my first ever change of inner sill, outer sill and heel board panel im very hppy with the end product
and as for the other side where im going to do all the same again hopefully it wil not take half as long
then once thats done ,and the boot floor and the air vents i can get on with the good stuff but t least once finished i no all the rust will also be done as well as the engine
Old 11-07-2008, 09:28 PM   #51
The Mighty Mallott
How come you've put oversills on? make sure you put some drainage holes in, or glug glug glug
She'll make 0.5 past lightspeed, i made a lot of special modifications myself.
The Mighty Mallott is offline   Reply With Quote
Old 11-07-2008, 10:23 PM   #52
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
i no they always say over sills are bad as cover all kinds of sins, but seeing ive put new inner sills in no theres no rust or problems
if i had put proper outter sills on i would not have been able to cover he joins in the floor all u would see is this
as outer sill would not cover
Old 12-07-2008, 07:44 PM   #53
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
well its another day and ive found more holes lol
only had a couple of hrs today to play with her so not much done today, but saying that in the short time i had ,,,,,,it up set me lol
well first i started cutting the rest of the back seat and the remaining bin out
as u can see if u look in the corner theres a big hole
and thats all i got done today hardly worth posting lol
and this is wot i was left with in my garage
just a pile of rust and bitumen on the floor
Old 12-07-2008, 07:48 PM   #54
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
god i so cantwait till this body work bananas is all done so i can start posting some interesting stuff, and start her looking like a 16v mini
Old 13-07-2008, 07:15 PM   #55
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
WELL ITS SUNDAY AND I HAD TO WORK TODAY LOL
so i only had 3-4hrs of playing with her
i thought i would take the rest of the bitumen up off the rest of the floors to see if there was anymore areas that need attention
and there was to my horror !!!!!!!!!!!!!!!
i was in 2 minds wether to weld a plate over it or to do it properly and cut the rust out and make a panel that will fit flush with the rest of the floor, my mate daz made me see reason that i may as well do it properly
so i cut the rot out !!!!
once the plate to repair the hole was cut i tacked a bolt to it so i could hold it just where needed as i tacked the plate in
then i seam welded it all up ,a bit at a time to make sure nothing warped
once finished i ground it back ready to prime it
gave it a good coat of zinc primer both sides
thaen i ran seam sealant round the welds for good measure
im in to minds now ref the other inner sill ,shall i replace the total inner sill or patch it ,as u can see below
tried to get a panoramic shot so u can see all the rust/rot/holes
but as u can see it did not quite work lol makes the sill look even worse pmsl
think at the end of the day i will end up putting the new complete innersill in ,if not i will never be happy knowing i did half a job lol
and in the long run it will cost me more as will need to do it all again in a few years!!!!!
Old 14-07-2008, 10:34 PM   #56
dazlee
dont blame me?
its always better to cut the rust out than to just cover it over and forget about it as the latter norm makes it worse lol
dazlee is offline   Reply With Quote
Old 20-07-2008, 04:05 PM   #57
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
Default the
well ive been after a spot welder since i started this project but never have the funds to buy one
so after some research i found this on ebay
with that all i needed was a arc welder, after looking on ebay i started to bid on some arc welders (there as cheap as chips) and i won this
so was well happy esp as only cost me 43 so with the arc and my good old trusty sip gasless mig welder i thought !!!!!!!!i had all areas covered !!!!!!
but then the good old mig decided melons it and stopped working
so i was prity grapesed off antill my mate had a mig for sale, only used twice and not wanting to much for it (still broke the bank lol )
but at least now i have a proper mig that should do me for years
Old 24-07-2008, 04:46 AM   #58
monkeyboy34
I see the large Abingdon minis sticker in the window, would that be Abingdon oxforshire? If it is i have a spot welder you can borrow, I'm only in wantage. Might have to buy some 1/8th copper rod for electrodes though (its an old school one, so you have to time it you self). Also for removing underseal you want some of these!
I used 3 of these in my grinder and stripped the whole underside of my mini back to metal in 1 day! They also come in flat and cup shapes. Mill hill tools in Didcot sell good ones, the screwfix ones fall apart in seconds. Trouble is, once you clean the floor you'll find alsorts of nasties!
monkeyboy34 is offline   Reply With Quote
Old 28-07-2008, 08:46 PM   #59
cooper_mark
cooper_mark's Avatar
Default Re: the
so have u tried it yet then.....if so was it any good as i am on the lookout for a spot welder or an attachment of somekind
my beast
Old 28-07-2008, 09:01 PM   #60
GRIFF2494
GRIFF2494's Avatar
CC: 1.8vvc
ECU: mems 2
hi again
ive been practicing with my new welder since igot it,(has so many setting i thought i bet get used to it before i go blowing big holes in the mini,by haing the settings wrong lol)
