Old 08-03-2011, 12:09 AM   #31
Coupe
Coupe's Avatar
That front end fits great - looks a good job.
Saloon K Series conversion sold
Clubby Estate K Series conversion sold
Coupe is offline   Reply With Quote
Old 09-03-2011, 11:57 PM   #32
Burnard
Burnard's Avatar
my new / redesigned dash
I added some stickers since then
Old 10-03-2011, 06:27 PM   #33
Burnard
Burnard's Avatar
Got a splitter from the scrappy today, only 5 so not a big deal if i dont use it.
Fitted for a quick mock up... im not sure to be honest :/
Also drilled the A pannels as per carbon weezles findings at mira:
Found a bumper trophy
Old 11-03-2011, 10:50 AM   #34
bhphunter
bhphunter's Avatar
Whats this all about then?
Dvaid.
build diary
Old 11-03-2011, 11:43 AM   #35
MarkGTT
MarkGTT's Avatar
ECU: MBE
carbon weezles did a load of aerodynamic testing with mira.
http://www.carbonweezel.co.uk/testing.html
i have the article on it somewhere.. not sure on the drilled a panels - could be in there somewhere.
Old 11-03-2011, 04:50 PM   #36
Burnard
Burnard's Avatar
Im pretty sure its been mentioned before on here...
But last year there were a few aero articles in mini world and mini mag, by vizard and carbon weezel (i think) They both said that drilling holes in the A pannels like that would reduce front end lift and drag.
Its a little hard to explain
Ill explain some more when i get back from work.
Old 11-03-2011, 04:54 PM   #37
kcchan
kcchan's Avatar
Basically a lot of the air entering the wheel wells (between the inner wing and outer wing/A panel) gets trapped behind the A panel creating drag etc.
Suck, Squeeze, Bang, Blow.
Old 11-03-2011, 04:56 PM   #38
bhphunter
bhphunter's Avatar
Ah well lets hope you notice the difference
David.
build diary
Old 11-03-2011, 10:30 PM   #39
Burnard
Burnard's Avatar
Well with the 998 it was pretty skittish at 85mph, and that was with fully adjustable suspension which had been professionally setup. I hope it does make a difference, but it looks good anyway
Old 16-03-2011, 08:28 PM   #40
Burnard
Burnard's Avatar
Got a bit carried away today.
Set out to get it in paint, so i put a coat on the front end.
Whilst waiting for that to dry, i thought i would see the damage behind the shock mounts (was planning on repairing these when i changed the subframe)
Found this:
Which isnt bad, poked it with a screwdriver, and not much happend.
Then the passenger side:
Damn right, shiny metal
I then fitted my new shock mounts, from mini spares.
Found i had a few runs on the front end, so sanded them out, and put a bit more paint on (btw, im useing holts paint cans which are bananase)
Figured id fit the brakes...
*Drool!*
Pretty discrete
Kam, wanna come and help me wash this car?
Got the windscreen in aswell, only took 15minute which is nice (im not mentioning the fact that was the 2nd attempt)
Old 21-03-2011, 10:45 PM   #41
Burnard
Burnard's Avatar
Something i borrowed from alex crosse's project.
Guess whats in the box.
The winner gets a bag of cookies if they are going to brooklands. (no joke)
Old 21-03-2011, 10:48 PM   #42
MarkGTT
MarkGTT's Avatar
ECU: MBE
Passengers side door?
Or shocks / coilovers
Old 21-03-2011, 10:49 PM   #43
HARBER07
HARBER07's Avatar
CC: 1598
Dunno, cam, steering column, gear shift, box of dust?
16v Minus Build Underway......
HARBER07 is offline   Reply With Quote
Old 21-03-2011, 11:01 PM   #44
cooper_mark
cooper_mark's Avatar
box of sparks for the grinder..........???
glass hammer.....??
box of rust..........??
my beast
Old 21-03-2011, 11:02 PM   #45
Burnard
Burnard's Avatar
Nope.
And before anyone asks (looking at you tom) its not a sex toy.
Got grinder sparks, you can see them there on the bench, just need to be warmed back up
