Go Back   16v Mini Club Forums > Classifieds > Wanted
Old 25-11-2017, 06:20 PM   #1
splintercat
ECU: standard rover
Default main fuses Rover
Just realised that i don't have ANY spare main fuses for car not too sure if they are called long fuses or short but need a couple of green 40AMP ones as sods law now I am fiddling about moving some wiring and switches, I will blow summat.......or the cat will ? :rolleyes It's the Rover/MG main internal box 6 main central fuses 60 40amp and 7 little blade fuses 10 25 20 etc need the central ones or where I can get em from.
splintercat is offline   Reply With Quote
Old 26-11-2017, 05:06 PM   #2
I will have these.
Any chance of a pic of what you need as there are so many variants.
Old 26-11-2017, 09:12 PM   #3
splintercat
ECU: standard rover
I will have these.
will send ya a pikky tomorow ta
Old 27-11-2017, 06:11 PM   #4
splintercat
ECU: standard rover
I will have these.
Pooh couldn't get a photo my phone has gone all girlie
however the fuse box is called an engine compartment fuse box for a rover 200
all the fuseblocks are 40Amp apart from one which is 80Amp.
The 40Amp ones have a part number of EAP 3179 they are Green body,
clear viewing box, and I think are called long fuseblocks as they are 6cms in length from end to end of the brass attachments.
Other than that the actual fuse box is part no....YPPP100310.
this is a 50AMP one from ebay eBay item number:352219786528 if that helps any ? I need similar but 40 Amp green
Old 27-11-2017, 07:35 PM   #5
You can take this complete fuse box if you like. I'm replacing the whole wiring loom including the fuse boxes...
PM me if you're interested.
Old 28-11-2017, 05:38 PM   #6
splintercat
ECU: standard rover
Brilliant mate thank you I would like that....
what does PM mean ? originally misread it as MP thought you mean Mince Pies as it is nearly Xmas...
Old 29-11-2017, 01:08 PM   #7
Messaged you...
It's a Private Message in the top right corner of main page.
