Go Back   16v Mini Club Forums > Classifieds > Wanted
Old 21-11-2017, 10:34 PM   #1
keitht
Default Honda Inner CV Joint Tripod Bearing
Hi Guys, I'm in a bit of a jam and need one of these ASAP. Has anybody got one they are willing to sell? Thanks
Old 22-11-2017, 06:57 AM   #2
Could try Watsons, or Hond-R at Abingdon
Old 22-11-2017, 11:55 AM   #3
keitht
Thanks for that, I have dropped both a mail.
Old 22-11-2017, 10:12 PM   #4
monkey
monkey's Avatar
ECU: A box of chips
There is a company called J and R driveshafts. They are on eBay and have a website. You could ask if they sell the inner cv joints separate but they do the complete driveshaft for about 26 quid.
Let us know if they do sell the inners separately. Only way I've found them separately is secondhand which is annoying.
Old 23-11-2017, 07:11 AM   #5
Yeah, J&R are good guys
Old 23-11-2017, 07:05 PM   #6
mikko
mikko's Avatar
ECU: obd0
jr only match external splines, everything inboard is non standard dimensions
Old 24-11-2017, 09:01 AM   #7
Ah, it's all coming back to me now !! (Forgive me, this was 2009 and I am around 50 ...)
I had the same problem - from memory, those bearing square plates aren't actually square, and break if you put them in wrong.
I got a complete driveshaft from J&R, and just used the inner CV / pot joint. Best option, especially for the price. Just make sure you get the right shaft, 'cos diameters and splines can differ.
