Go Back   16v Mini Club Forums > Classifieds > Wanted
Old 04-10-2017, 08:23 AM   #1
Default rover torsen diff & light flywheel, pg1 box etc
I am after (for a friend) a Rover pg1 torsen diff, lightweight pg1 flywheel, PG1 c6 gearbox, gear linkage and some mgf/rover pg1 driveshafts (doesn't matter which rover as long as its pg1). closer to northamptonshire the better (or will pay postage).
Cheers!
Old 02-11-2017, 08:22 AM   #2
still need a torsen, lightweight flywheel and gear linkage
Old 04-11-2017, 10:21 PM   #3
benvvc
benvvc's Avatar
what is a non vvc pg1 box with a type a diff fitted worth?
Old 06-11-2017, 07:38 AM   #4
Hard to say really as prices vary so much and the type a is the less desirable (type b is stronger). But i would guess around the 200 mark
