Old 24-08-2011, 09:07 PM   #16
I am thinking you should not touch the estate till I am there jerry lol
Old 24-08-2011, 09:24 PM   #17
Hayling mini
Hayling mini's Avatar
CC: 1340
ECU: Haltech
Originally Posted by miniswift View Post
Hi Jerry,
You know you can move back your engine by 1".
Allan told me that there is a captive nut already there as if Subaru knew it!
So may be you can fit into round front with 4" extension!?
Atchi
Not sure about changing the engine position yet, hopefully the Clubman front should give us enough room. The GTI engine will hopefully be fitted tomorrow
LOL, you had better get over early next week then, my Plasma cutter should arrive tomorrow & I cant wait to try it out. Keep thinking about the roll cage, I would really like this one to look bog standard. But I am concerned about the strength if we don't fit one
Old 24-08-2011, 09:35 PM   #18
Yes same here in both minds about cage. Don't know
Old 24-08-2011, 09:48 PM   #19
Hayling mini
CC: 1340
ECU: Haltech
Maybe a cage in the rear & hidden box section in the front?
Old 24-08-2011, 09:55 PM   #20
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
oŽboy you lads work fast, looking good though
Are you doing it the exact same way as the last one?
Old 24-08-2011, 09:56 PM   #21
kcchan
kcchan's Avatar
You could try and build a cage that fits really tight against all the pillars so that it doesn't look too obvious.
The one build here is what I mean
http://www.16vminiclub.com/forums/sh...?t=7665&page=4
Suck, Squeeze, Bang, Blow.
Old 24-08-2011, 09:59 PM   #22
Hayling mini
CC: 1340
ECU: Haltech
This one is different, with all the lessons learn t doing the van
Old 24-08-2011, 10:02 PM   #23
Burnard
Burnard's Avatar
Or in other words, this is going to be yours, and give the van/estate to the missus.... lol.
Old 24-08-2011, 10:26 PM   #24
I think your van was weak when we removed then cage ties because it was de seamed.
Let's get the shell on and see where we are as we said the cage is bolt in
Matt
Old 24-08-2011, 10:30 PM   #25
Hayling mini
CC: 1340
ECU: Haltech
Matt
I agree, I will look in Rogers store tomorrow & find some more strengthening bits
Old 25-08-2011, 11:00 AM   #26
Spiyda
Jerry,
How have you welded the box section to the sills ?
is it just welding the edges of the existing holes on the outside, or have you got welds on the inner sill ?
can't quite see it on the picture
Chris
Old 25-08-2011, 11:32 AM   #27
it will be welded through the inner sill as well
Old 25-08-2011, 05:23 PM   #28
Allan McD
Allan McD's Avatar
CC: 2350 t
I heard he was just going to use cable ties and duct tape
Allan
My new shop http://www.aandgmotorcycles.co.uk
Old 25-08-2011, 05:52 PM   #29
spNOam
spNOam's Avatar
ECU: Tweaked DTA
Maybe some sticky back plastic?
To insanity & beyond!!
Geoff
Old 25-08-2011, 06:55 PM   #30
Hayling mini
CC: 1340
ECU: Haltech
Engine all rebuilt & in the car
Vic playing with the new Plasma cutter, I can't believe how good it is for Ł299.00
