#46 |
ECU: Emerald
Gave the front end a coat of zinc primer and couple layers of stone chip paint, made a start on the turbo support bracket also tried sorting the fuel leak on the fuel rail adapter couldn't stop it leaking turned out to be small crack in the fuel rail!
![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#47 |
ECU: Emerald
Finished turbo support bracket and done a bit more on the body prep
![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk ![]() |
#48 |
ECU: MBE 967EF
Your sanding blocks seem to be adding filler rather than removing it.
Sent from my D5503 using Tapatalk |
#49 |
ECU: MEMS I THINK
Looking good!!
#50 |
ECU: Emerald
If it all goes to plan should have some paint on it in a couple weeks!
#51 |
ECU: Emerald
Had a spare hour this morning wired up the fuel pump and made a start on the digi dash just waiting for a couple sensors then dash will be finished
#52 |
When do we get to see this running?
#53 |
ECU: Emerald
#54 |
ECU: Emerald
![]() Apart from the rattles and smoke it's perfect haha smoke is from where I poured some oil in the bores should burn off? Sent from my iPhone using Tapatalk |
#55 |
Nice, looking forward to hearing at full chat.
Not long to wait! Sent from my iPhone using Tapatalk |
#56 |
ECU: Emerald
#57 |
ECU: MBE 967EF
Why is it whenever we do videos of engines running they all sound like diesels?
#58 |
ECU: Emerald
#59 |
ECU: MBE 967EF
Yes mine always sounds like the lifters are shagged but in real life it sounds fine
#60 |
ECU: Emerald
Treated my self to some force racing wheels picking them up Wednesday!
Thread Tools | |
Display Modes | |
