Old 31-12-2017, 06:11 PM   #391
Superb!
Old 06-01-2018, 11:55 AM   #392
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Not sure how you post pictures from Flickr rather than just links?
Old 06-01-2018, 04:24 PM   #393
Click on the photo you want to post, it will come up in a new window, down on the bottom right you will see an arrow that sweeps to the right, When you hover over it it says "share" click on it, new window opens. The first box is the image code that you copy the lower box is the picture size I use medium 800 x 600 but you can use what you like but when you go bigger they go off the side of the page, also enter a couple of time after the image code and this separates the pictures so that they aren't all one long collage with no gaps, can be a bit hard to differentiate between photos.
Old 06-01-2018, 05:30 PM   #394
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Maybe I need to do it through a browser as the app doesn't work like that.
Old 06-01-2018, 08:50 PM   #395
Cant see anything wrong with that photo
Old 06-01-2018, 09:18 PM   #396
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default NudgerSS 1.6 16v
Thatís not from Flickr though Inspector Gadget. A few of my photos were too high res to mount directly on the forum.
In fact Iíve no idea why that photo appeared on that post. Bizarre.
Old 25-02-2018, 05:08 PM   #397
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Decided to bite the bullet and finally sort the pipe work on the cooling system. My inlet manifold has never had the outlet to go to the heater so took the lot off and started drilling the hole out. Waiting for my 3/8 npt tap to come before I take it out any bigger. A barb will then be fitted to enable hot water to go to the heater.
Old 25-03-2018, 01:03 PM   #398
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Done a bit of tarting up on my tatty cam cover. First time I've used any crackle paint so I'm going to assume this is a decent finish.
Old 25-03-2018, 01:20 PM   #399
Fix the heating just in time for the summer,
Old 25-03-2018, 01:47 PM   #400
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Prefer to think of it as extra cooling Shaun
Old 25-03-2018, 10:42 PM   #401
Like it johnner, Wales?
Old 26-03-2018, 06:58 AM   #402
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
No I'm in England Shaun.
Old 26-03-2018, 10:52 AM   #403
You know you want to,
Old 26-03-2018, 06:08 PM   #404
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
All fitted up, sweet as a nut. Stainless bolts too for extra points.
Old 26-03-2018, 07:27 PM   #405
pipsovich
Looks really race-y! Nice!
Have you measured the power in the engine?
Any nice movies recently filmed?
