Old 25-02-2009, 11:39 AM   #16
maph2
ECU: MBE
do you still have those 12" saxons?
72 Morris Mini Clubman, C20XE, 150bhp, 136lbft
'79 Saab 99 Turbo 150bhp
maph2 is offline   Reply With Quote
Old 25-02-2009, 11:46 AM   #17
you might have problems with that clutch slave mounted to the subframe , as when the engine rocks the clutch position will change.
(you should look into the internal slave from vauxhall , much nicer)
also you can get a short stubby oil filter of a TD vauxhall , gives you more room for rad etc.
Matt
Old 25-02-2009, 07:40 PM   #18
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Yes maph I've still got the wheels. They are up for grabs if you're interested. Looking for about 200 for the 4. Tyres are pretty good on them too.
Matt I had wondered about the mounting of the slave. Didn't fancy the concentric slave with it sitting inside the gearbox housing so though I would give this a go. May even end up sticking with a cable operated clutch in the end. Thought this might just feel a little less snatchy
John
Old 25-02-2009, 07:47 PM   #19
hydric is the way to go , much better than cable , but dont worry about the internal jobbie , cheap to buy new , they will out last anything else on the engine ..
Matt
Old 06-04-2009, 07:30 PM   #20
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default NudgerSS 1.6 16v
Well my throttle bodies have turned up so decided on a trial fit
Unfortunately they were nowhere near fitting so out came the grinder....
Quite a big hole as you can see. Just need to get it all boxed up n good as gold. Should be some nice induction roar in the cabin with the air filter being under my nose!
John
Old 08-04-2009, 07:52 PM   #21
captainjack15
captainjack15's Avatar
CC: 1590
Send a message via MSN to captainjack15
Nice work Keep it up
I want a 1.6 some day *comes back to reality* :P >_<
captainjack15 is offline   Reply With Quote
Old 08-04-2009, 09:58 PM   #22
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Had a slight setback tonight. Started welding the bulkhead box in and thought best just check fitment of throttle bodies.
Yep they fit ok with air filter on. Errrrm how will I get the air filter off? Look like going for some more sheet metal tomorrow and making the box an inch or so deeper.
These things are sent to try us
Old 08-04-2009, 10:31 PM   #23
garyshoose
garyshoose's Avatar
CC: Sold
ECU: Honda
Shouldn't ever need to blow your nose again though
garyshoose is offline   Reply With Quote
Old 24-04-2009, 06:27 PM   #24
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Managed to get a little bit done this evening. Bought some 1.6 sheet and made myself a LARGE bulkhead box to house my throttle bodies and got it partially welded in
Doesn't leave much room for instruments inside tho
Old 24-04-2009, 07:44 PM   #25
tommi_balls
Send a message via MSN to tommi_balls
oops just dribbled everywhere
Subtle as a Sledgehammer
tommi_balls is offline   Reply With Quote
Old 24-04-2009, 07:52 PM   #26
captainjack15
CC: 1590
Thats nothing >_<
I've got serious problems over here
Old 14-08-2009, 03:54 PM   #27
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Well things have been going very slowly lately as I seem to be lacking enthusiasm. Started to try and work out the wiring for the sensors to megasquirt n got most of them matched up
Done a bit of a mod job on a pedal box as I need to be floor mounted
Got my throttle bodies and linkage sorted
and bought a few more bits
John
Old 14-08-2009, 04:00 PM   #28
hang in there mate , its tough sometimes ...
looking good... and you picked a good choice of ECU
give us a shout if you got any problems.
Matt
Old 14-08-2009, 04:09 PM   #29
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Cheers Matt. Good choice of ecu maybe but bad choice of supplier. Can you guess??.....
Thats right M-tech
Not tried it out yet so got everything crossed that its a rare good un!
John
Old 14-08-2009, 04:11 PM   #30
nah ... not m-tech .. gutted ... fingers crossed its a good one ...
Jay on vaux-extreme is good at sorting out there mess if needed.
Matt
