Old 18-12-2007, 10:07 PM   #31
mininut
ECU: Trionic 5.5
Done the offside turret, will do the nearside one later this week and post some pics of progress.
M.
Old 30-12-2007, 09:40 PM   #32
mininut
ECU: Trionic 5.5
Finished off the turreting today, only to realise after cleaning the boot that the rear boot floor corners need replacing... oh well.
I'll post up some pictures later.
M.
Old 01-01-2008, 10:17 PM   #33
mininut
ECU: Trionic 5.5
A couple of snaps of what i've been upto, the turreting...
Found that the boot corners needed replacing too, so will do that next...
And the rear beam I'm working on...
M.
Old 01-01-2008, 10:20 PM   #34
lawson
Send a message via MSN to lawson
Default nice
very nice mate i what you got to do next mate
lawson is offline   Reply With Quote
Old 01-01-2008, 10:21 PM   #35
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
looks solid, good craftmanship there mate
//marcus
Old 01-01-2008, 10:22 PM   #36
lawson
Default cut
get brave and cut the boot floor out and get one like mine
Old 01-01-2008, 10:37 PM   #37
mininut
ECU: Trionic 5.5
Thanks guys. Still have to replace the corners even if i get a carbon floor like yours Dave
M.
Old 02-01-2008, 08:53 PM   #38
rob bailey
hello pal when u was doin the turret what mm of steel did u use and how did u measure so they are the same or hav u only done one side?
rob
rob bailey is offline   Reply With Quote
Old 03-01-2008, 12:11 AM   #39
mininut
ECU: Trionic 5.5
rob
The steel is 3mm, i had the steel bent for me so it was 3.5" diameter but only half, bit like a gutter.
M.
Old 29-02-2008, 05:55 PM   #40
lawson
Default yo
any more progress yet mate
Old 01-03-2008, 06:12 PM   #41
mininut
ECU: Trionic 5.5
I've managed to get the boot corners done, was going to make a start on the trailing arms this weekend but everyone is ill so they need looking after!!
M.
Old 06-04-2008, 06:07 PM   #42
mininut
ECU: Trionic 5.5
Finished off the boot corners and got some seam sealer on it, just need to decide whether to change the battery box or put in a flat floor...
Got the on car adjustable rose joint mounts done for the radius arms. There are 3mm thick bosses tig welded inside the 30mm box in case you're wondering if its just a hole in the box tube!! Need to make up a mounting plate for the hub now and make up the rest of the arms...
Took the p/s sill off, can't decide on whether to change the inner sill or not, might just patch up the 2 little holes and seal it, then drop a new outer sill on... thoughts welcome for this, is it bad enough to change it or not??
Old 06-04-2008, 06:32 PM   #43
Geehawk
Geehawk's Avatar
If that really is the extent of the rot then I'd patch it.
Mini T-Shirts
TheClubman.co.uk
Old 06-04-2008, 07:02 PM   #44
jasonb89
Send a message via MSN to jasonb89
same looks pritty good as well so just patch it i would say. the rear disc conversion look like its coming along now, its spured me on to start mine now
Parts For Sale :(!
jasonb89 is offline   Reply With Quote
Old 06-04-2008, 08:03 PM   #45
Marcus Nordblom
ECU: 40mm mikuni rs
why not locate the muffler in the place of the batteri box, then you can go real low…
By the way, TOP WORK realy keen to see the arms etc.
//marcus
