Old 19-01-2017, 03:06 PM   #241
Originally Posted by mininut View Post
Dont know what ECU your running but some are mega mega fussy and will throw a code with that cam alignment. if its not to much hassle, get some feeler gauges to pack out that cam locking bar so the slots are totaly flat and re-check your timing.
Old 19-01-2017, 03:18 PM   #242
mininut
ECU: Trionic 5.5
Denis, that's how it came off the crate! I had to put the mazda crank pulley on it and got it as close as i could, had to use the Mazda crank sensor too so realigned it to the main pulley. should be ok, will need a remap anyway since its a larger capacity now then another remap when the blower is fitted after running it in.
Old 26-01-2017, 10:41 PM   #243
mininut
ECU: Trionic 5.5
Finally got the mx5 started, done first oil change just a few other odds and sods to do before it's on the drive and the mini gets some time.
https://youtu.be/dy91EBh99Kc
Old 27-01-2017, 01:17 AM   #244
result,,
I hope the sound is I phone zoom auto compression coz it sounds like something camy
is clacking, but theres been lots of films lately that sound that way and sound normal too the humain ears,
Old 27-01-2017, 09:54 AM   #245
mininut
ECU: Trionic 5.5
result,,
The sound was the power steering pump, I'd filled the reservoir but it hadn't worked round to the pump, once I filled it to the correct level the noise stopped, its running very quietly
Old 07-02-2017, 10:46 AM   #246
mininut
ECU: Trionic 5.5
Finally I can start to run the raspberry in...
Old 23-02-2017, 01:27 PM   #247
mininut
ECU: Trionic 5.5
The MX5 exhaust midpipe broke at 50miles into the run in process so I thought I'd weld that up and change the backbox while it was out so made this...
This is 3" twin box, the midpipe is still 60mm and won't support the power levels I want to achieve, i plan to make a jig of that after i've fixed it then make a 3" midpipe myself. I refuse to pay around 600 for a midpipe on the NC when you can buy a 3" one in stainless for the NA/NB for well under 400!
Old 03-03-2017, 07:19 PM   #248
mininut
ECU: Trionic 5.5
Finally, on the road and running in...
Old 25-05-2017, 02:40 PM   #249
mininut
ECU: Trionic 5.5
Just got 1000 miles on the new motor and had it calibrated, this thing is a tool lol not sure if the mini is going to see any action for a while if ever!!
Old 25-05-2017, 02:40 PM   #250
dont be a girl !
MattG is online now   Reply With Quote
