Old 27-08-2007, 06:32 PM   #1
mininut
ECU: Trionic 5.5
Default The MiniNut 4x4 rebuild
As the big ends are now shafted because the oil pump failed, i thought i would use this opportunity to do some changes to the car that i've had planned for some time. I took some pictures of the cutting i've done so far...
All the lovely leather out...
The passenger side door has been reskinned...
The drivers side needs the same treatment but the frame is shafted and i need another...
A very sad picture
Back seat structure removed...
I've cleaned up where i'm planning to tub the rear arches...
Will post more pics once the rebuild progresses.
M.
Old 27-08-2007, 08:47 PM   #2
wee man
wee man's Avatar
thats the way to do it. Wanna borrow me stihl saw. got a nice boot floor goin if your feelin brave
Old 28-08-2007, 03:26 PM   #3
bodgeit
CC: 998
ECU: Yamaha
nice one maz!
why the massive hole in the rear set though?
Matt
If in doubt, paint it black.
Just add lightness!
Old 28-08-2007, 04:15 PM   #4
mininut
ECU: Trionic 5.5
Originally Posted by bodgeit
nice one maz!
Matt
I had two 12" subs bolted into the boot... will plate it up during this build.
M.
Old 28-08-2007, 04:32 PM   #5
bodgeit
CC: 998
ECU: Yamaha
ah i see
Matt
Just add lightness!
Old 28-08-2007, 04:33 PM   #6
Geehawk
Geehawk's Avatar
nice one maz!
Matt
So he can carry a flourescent light in the boot lengthways
Mini T-Shirts
TheClubman.co.uk
Old 28-08-2007, 05:51 PM   #7
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
so far so good, canīt wait to se it finnished :P
marcus
Old 28-08-2007, 10:52 PM   #8
mininut
ECU: Trionic 5.5
Started the tubbing today, taking a lot longer than i thought. Not so easy with only 1 body to weld and fire watch!!
I'm surprised at how much the quarter panel warped with the heat. Luckily nothing a dolly and hammer won't fix.
Old 29-08-2007, 07:57 AM   #9
BassAddict
CC: 1798
Hope its not off the road for too long Maz - good luck with all the jobs
Rch
Old 29-08-2007, 09:48 AM   #10
mininut
ECU: Trionic 5.5
Rch
Thanks matey, I hoping if i keep this pace then it shouldn't be off the road for very long. Keeping the same pace is the problem though!!
M.
Old 29-08-2007, 10:52 AM   #11
Geehawk
Geehawk's Avatar
I'm getting Security certificate errors with your latest pics Maz.
The early ones appear fine, but I have to accept the error to see the later ones
Mini T-Shirts
TheClubman.co.uk
Old 29-08-2007, 01:11 PM   #12
mininut
ECU: Trionic 5.5
yeah, i got that, i can't understand why as they're all hosted from the same path on the same machine.
M.
Edit, pictures sorted now, should be no security issues.
Old 29-08-2007, 08:47 PM   #13
Tom
Tom's Avatar
ECU: Webcon Blue
Looking good, I kinda wish I'd tubbed my arches.
My Build Diary
Tom is offline   Reply With Quote
Old 30-08-2007, 08:44 AM   #14
Geehawk
Geehawk's Avatar
M.
Everythings now A O K
Mini T-Shirts
TheClubman.co.uk
Old 30-08-2007, 10:51 AM   #15
Mintegra
Mintegra's Avatar
ECU: JDM OBD2
Sorry for being nieve - but what is the reason for tubbing the arches??.. extra strength??..
C
