Old 16-11-2017, 02:23 PM   #31
Basil
CC: 1598
Alternator bracket now all done
Got some glass in, changed to some opening rear quarters as they matched the fronts, turned out all my glass is different colours
Interior is starting to come together, had to change to some different seats a mouse ate one of the Speedwell seats.
Brake lines are now all done
Old 24-11-2017, 10:11 PM   #32
player14
Send a message via MSN to player14
Great progress.
How does your manifold and air filter sit with your alternator there?
Iíve sourced an alternator from a Suzuki swift so going to try a similar mounting position to yours.
www.eastcoastminis.org.uk
player14 is offline   Reply With Quote
Old 17-06-2018, 09:29 PM   #33
Basil
CC: 1598
Thank you to Matt Green for getting me back into my account, here's some updates from the last few months.
Engine bay almost done
Made up a shroud to protect the radiator
Old 17-06-2018, 09:36 PM   #34
Basil
CC: 1598
Finished getting the rad all plumbed in.
This is what underneath the roof looks like
The inlet clears the alternator with plenty of room, had to make a pipe out of steel to get the angles needed for one of the hoses.
Got the glass in, just need to do the locking strips. Theres a few ways to do this, we did it by putting the seal in the car then putting the bottom of the glass in as best we could and then with some levering in with a screwdriver, a lot of pushing and pulling from inside and out it went in no problem.
Also got the mounts for the bonnet pins done.
Did the engine wiring before, now have spent about 8 hours sorting the mini side of things, is all neat tidy and works as it should and as always any questionable wiring has been removed and replaced.
Old 17-06-2018, 09:38 PM   #35
Basil
CC: 1598
Now taxed and MOT'd!
Old 17-06-2018, 09:41 PM   #36
Basil
CC: 1598
Fan switch on the dash panel
Went to it's first show on Boxing Day
Had it's first breakdown.
And a few pictures of it pretty much finished
Few jobs lefts which are.
- Get suspension set up, everything is miles out
- Put a bit more carpet it
- Oil and filter
- Get on ramp, strip back, repaint and underseal
- Put door and bonnet roundels on
- Sort speedo cable and gauges
Old 17-06-2018, 09:45 PM   #37
Basil
CC: 1598
Carpet is in.
Tracking and toe is done but still needs camber and castor.
Given it a good clean, will be on the show and shine at London to Brighton.
Old 18-06-2018, 05:39 AM   #38
Mini Vlatko
Mini Vlatko's Avatar
Wow! Love this build and final look! My level of dedication to detail!
I'm especially loving how you managed to squeeze the alternator in the back and kept it all stealthy under standard front!
Old 18-06-2018, 09:05 AM   #39
Proper nice , looks like a mini ,
Old 20-06-2018, 11:09 AM   #40
love colour scheme
Old 21-06-2018, 07:54 AM   #41
Dopeshow
I love the look of this. looks like an old school Cooper S.
Nice work !
Old 25-06-2018, 09:06 AM   #42
player14
Smashing looking mini - well done!
Old 07-11-2018, 11:17 PM   #43
Basil
CC: 1598
Thank you everyone.
Little update
Went to London To Brighton
by the book oil change
Local show in Tewin
Photoshoot for Mini Magazine, can't believe I have to wait until it's published before I can see the pics!
New ECU ready for new engine.
Is called a Speeduino, is basically a mega squirt but a bit more DIY and a lot cheaper. Is wired into existing ECU plug so will be plug and play.
Ready for new engine to go in which is E16SE, ported head, C16SE inlet, red top injectors, 288 cam, ARP rod bolts, uprated fuel pump. Might get a lightened flywheel to go in. Should be going in over the winter.
Old 25-11-2018, 10:26 PM   #44
player14
Will be very interested to hear how the upgrades improve performance
