Old 12-10-2018, 10:42 AM   #211
Love the seats
Old 10-01-2019, 11:44 PM   #212
Not updated this in a while as Iíve not got any new photos..
Iíve been busy finishing welding up the seat mounts, got a new crossmember delivered today that Iím going to do a neater job of modifying round the seat mounts before I fit it, also ordered a hole swager to make some speed holes in it because racecar
Hoping to get the floor finished and the car stripped to roll it on itís side and paint the underside and possibly inside by the end of February, but thatís just a loose date...
Iíll add photos once Iíve got some
Old 21-01-2019, 04:26 PM   #213
Started modifying the crossmember around the seat mounts and still in the middle of cutting the old one out. Forgot how much I hated cutting out old panels
Old 21-01-2019, 05:44 PM   #214
It's when you start cutting a little out of an old panel that look's a little crusty and it ends up being a full panel and several others that were attached to it!
Old 21-01-2019, 08:37 PM   #215
Glad that stage of the build is long gone... Only got a tiny bit of the crossmember left to remove and hopefully thatís the last panel Iíll need to remove on the car. Itís my own fault anyway, it was a new panel I already fitted when I replaced the floor, I just cut into it too much when I was fitting the seats
