Old 30-10-2017, 01:13 AM   #1
mininut
ECU: Trionic 5.5
Default Garage clear out, saab engine, f20 +LSD, c20xe head, cams, pulleys, turbo manifold.
It's been sat for 9 years, can't see me getting it done so selling off some project stuff as i need the space, will decide in the new year if everything else goes too or...
Saab b204 engine, loom and 2x ecu, looking for 450obo
F20 gearbox with Quiafe ATB LSD, the casing is f20 with F18w internals (longer gearing) + 2 half shafts, 700 obo
C20XE/C20LET polished and ported cylinder head, double valve springs, its got piper 276 cams and piper vernier pulleys on it. Head has only seen about 2K miles and about 12 months of coolant in it since new. 450 obo
Courtney turbo manifold, its got a T3 flange welded on top of the t28 so can be used for both. 120 obo
All items are collection only from B76, i may be able to post the turbo manifold at buyers expense.
Old 06-11-2017, 10:55 AM   #2
baz_rsp
baz_rsp's Avatar
Who did the work to the head??
baz_rsp is offline   Reply With Quote
Old 08-11-2017, 08:09 PM   #3
turbo_dazer85
ECU: LET Standard
id be interested in the courtney manifold if you could post?
Sent from my SM-G925F using Tapatalk
turbo_dazer85 is offline   Reply With Quote
Old 12-11-2017, 08:55 PM   #4
mininut
ECU: Trionic 5.5
I did the work, all ports were volume tested to make sure they were the same.
Old 19-11-2017, 10:41 AM   #5
wee man
wee man's Avatar
that sounds like it's going to be the end of the mininut?
12.71@108.44
