Old 15-07-2016, 09:45 PM   #31
Kam
Kam's Avatar
Originally Posted by Stuart80 View Post
I would like to get mine done anyone know the length of shafts need for the allspeed set up
Check the link provided in the following link, there are two different lengths depending on the 'mini' end if it will be HD allspeed or just standard mini
http://www.16vminiclub.com/showthread.php?t=27941
Old 06-12-2016, 07:42 PM   #32
sebastiaan.keijzer
ECU: KMS
I send you a email. Hopefully you can Help me.
Thanks,
Sebastiaan
sebastiaan.keijzer is offline   Reply With Quote
Old 24-02-2017, 04:08 PM   #33
gav
ECU: Emerald
How do you guys measure ideal length? Just make sure the inner joints don't bottom out inside the joint when the shaft is completely horizontal?
gav is offline   Reply With Quote
Old 25-02-2017, 11:43 AM   #34
Mock it up with a broom handle and keep cutting it to length and measuring. Just an idea..
Old 03-07-2017, 02:45 AM   #35
Bieben
Hello,what are you mian custom?
tiema TRUCK PARTS
Bieben is offline   Reply With Quote
Old 03-07-2017, 09:47 AM   #36
This is service to join two different types of driveshaft together. For example a Honda engined Mini will need Honda driveshaft from the gearbox but then a Mini driveshaft on the outer end.
