Old 27-09-2018, 10:38 AM   #1
nerdymind
nerdymind's Avatar
CC: B16
Default Car Wont Start
Hi There,
Every time when i turn the key ignition on there is sound like fuel tick then i start the car and it starts.
now i can't hear that tick.
what could be the problem? i didn't start the car from a month because i was busy.
Thank you
Ayman
nerdymind is offline   Reply With Quote
Old 27-09-2018, 12:50 PM   #2
Sounds like the fuel pump is not running. Check fuse and relay
Old 30-09-2018, 06:10 AM   #3
nerdymind
nerdymind's Avatar
CC: B16
I Checked the fuse and looks good and maybe the relay
yesterday when i checked the fuel was very low and maybe i was running the car on low fuel, is that going a problem to the fuel pump? i just wana know if changing the reply will not help
Thank you
Ayman
Old 30-09-2018, 06:30 AM   #4
What pump are you using Ayman ?
Old 07-10-2018, 08:17 AM   #5
nerdymind
nerdymind's Avatar
CC: B16
MPI one
the original mini ones
Thank you
Ayman
Old 07-10-2018, 08:29 AM   #6
As Oz said, you need to check the relay, and the wiring to it.
Just changing the relay may solve it, if you're lucky, but may not.
Checking is best.
Old 07-10-2018, 09:24 AM   #7
nerdymind
nerdymind's Avatar
CC: B16
if not the relay? what could possible will be?
its my mistake to keep the car there without starting it every week, its been stopped for a month and half.
Thank you
Ayman
Old 07-10-2018, 11:14 AM   #8
My car's been unused for the last 18 months, and has recently been started, and runs fine.
This is not the problem.
You don't have to start it every week - better to take it for a run occasionally.
Think you should start by testing the relay ...
Old 07-10-2018, 11:37 AM   #9
nerdymind
nerdymind's Avatar
CC: B16
yes let me check the relay first and see.
anyone knows a website that easily i can order one
Thank you
Ayman
Old 15-10-2018, 07:57 AM   #10
filski
Same problem here ticking stopped and no prime at the fuel pump, but if I bridge the relay pins for fuel pump and constant live pump works fine, check relay first by taking it out and looking at solder on the pins. I am yet to find time to do mine as the relays are not cheap and many say that there not a lot in them to go wrong other than pants soldering
Old 15-11-2018, 09:27 AM   #11
nerdymind
nerdymind's Avatar
CC: B16
Checked da Relay and shows that the ECU Box have been failed to start the engine
Thank you
Ayman
Old 15-11-2018, 11:13 AM   #12
Haz
I can't offer any help further than what's already been suggested... I just wanted to know where abouts in KSA you are? I work there in ta'if on a rota, usually a month on 2 months off. I'll be there again 2 weeks tomorrow.
Is your mini over there?!
Old 15-11-2018, 11:52 AM   #13
nerdymind
nerdymind's Avatar
CC: B16
Great, am in Jeddah
if you can help me will be great
Thank you
Ayman
Old 15-11-2018, 01:03 PM   #14
Haz
If I get chance to visit Jeddah one weekend I'll let you know pal. All depends on my colleagues though, I can't drive myself there due to a 30km daily restriction on my hire car.
Old 18-11-2018, 07:35 AM   #15
nerdymind
nerdymind's Avatar
CC: B16
Great, we can do that
no problem we can solve that
Thank you
Ayman
