Old 09-10-2018, 10:00 AM   #1
ochumi
Default question about coilovers spring
Hi im building a honda d16a9 engine, i put the protech coilovers with this spring
D Faulkner Springs LLP
REAR
1.9 Inch ID 9 Inch Free Rate: 150lb
FRONT
1.9 Inch ID 8 Inch Free Rate: 425lb
I see the car a bit high and the shock absorber nut is as loose as possible, and I do not know whether to change the rear springs to 8 "and the front ones to 7" in length, or that it has to stay that high. ..
also for the fronts in 7 "there is only up to 400lbs I would have to go to 2.5" for a load of 425lbs ...
I do not know how you see it
thanks
ochumi is offline   Reply With Quote
Old 09-10-2018, 06:05 PM   #2
Rally Design do heavier 7" springs (but they're yellow ...)
