Old 18-02-2017, 07:10 PM   #1
choochoo
Default Swift fuel pressure
Does the swift gti have a built in fuel pressure regulator . It looks like there's one on end of the fuel rail?
If not what fuel pressure do they run?
Thanks Tom
choochoo is offline   Reply With Quote
Old 18-02-2017, 10:50 PM   #2
sebastiaan.keijzer
ECU: KMS
Its at the End on the fuelrail. 2.9bar is Nice when using a aftermarket pressure regulator.
You can easily modify a MK1 Swift fuel rail. Ive got 2 OR 3 somewhere. I sold my Estate with Swift gti engine.
If you need something or advice you van ask me.
Regards
Sebastiaan
sebastiaan.keijzer is offline   Reply With Quote
Old 18-02-2017, 11:06 PM   #3
choochoo
Thanks you
I've just fitted another fuel pump that runs 6bar I think. Will that be ok as it has regulator fitted
Old 18-02-2017, 11:12 PM   #4
sebastiaan.keijzer
ECU: KMS
Yes, 6 bar is more than enough!
Old 19-02-2017, 11:45 AM   #5
choochoo
Do you have wiring loom diagram for loom for start ignition etc so I know what I can remove from the loom
Old 19-02-2017, 04:46 PM   #6
sebastiaan.keijzer
ECU: KMS
Send me a email. Keijzer@outlook.com and i Will send you some diagrams
Old 19-02-2017, 06:47 PM   #7
choochoo
Done . Thanks mate
