Old 14-08-2009, 04:17 PM   #31
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Yeah I've been over on there and noticed you had posted a few times when building yours. Seems like quite a knowledgeable bloke
John
Old 28-09-2009, 07:46 PM   #32
the matt
CC: 1618
ECU: Canems
Send a message via MSN to the matt
Quick Q? Where have you plumbed the expansion tank in? Or haven't you done it yet?
the matt is offline   Reply With Quote
Old 28-09-2009, 08:34 PM   #33
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Not done it yet. Yet another job that needs ticking off. Had to spend a bit of cash on the Punto this month in readiness for the MOT so things have been delayed slightly. That and the fact that I can't seem to be peachd...
John
Old 29-09-2009, 06:59 PM   #34
the matt
CC: 1618
ECU: Canems
Yeah, missing the 'ring run deadline with mine has given me a total loss of motivation!
BUT, I'm back on it now, tried to sort out the plumbing at the weekend and got to the expansion tank and though 'Aaah, where to tap the expansion tank into?' lol
Old 29-09-2009, 09:51 PM   #35
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Yeah my target was Coombe, ahem, last year then this year
Not sure if petrol will be available by the time its actually done!!
Cheers - John
Old 15-11-2009, 11:11 PM   #36
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default NudgerSS 1.6 16v
OK well its been a while but I managed to spend a couple of hours on it on Saturday. Got my pedal box bolted down and a bit of the plumbing done. Not sorted brakes yet (hopefully Monday night) but I've got a clutch Think I need to put a bit of extra metal down on the floor to spread the load a bit tho.
Old 16-11-2009, 08:55 PM   #37
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Did a bit more tonight and got the brakes plumbed in too. Just waiting on my brake pads coming then I can try n get em bled. Need some clips to fasten all the pipes down/together too.
Old 16-11-2009, 10:59 PM   #38
mininut
ECU: Trionic 5.5
i'd be soo paranoid about standing on those brake lines!
Old 16-11-2009, 11:16 PM   #39
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
LOL! Don't worry they are going to be covered up. Need to get some thicker plate to make a foot rest
John
Old 02-02-2010, 11:43 PM   #40
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Well not much to report as of late.
Painted my bulkhead box, fitted TB's, plumbed cooling system in, fitted fuel pipes, finished wiring Megasquirt in, put some petrol in AND.......nothing.
Bugger.
Not getting a spark. Changed a few settings thanks to Jay at Vaux-Extreme but still no luck. Off to the scrappies on Saturday to look for a 3-wire Ecotec coilpack as the amped ones are tosh apparently.
Cheers- John
Old 03-02-2010, 04:41 PM   #41
alexcrosse
CC: 1598
ECU: MBE 967 EF
I got the SBD one, seems pretty good to me. If you need a spare C16XE coil pack i might have one, i can have a look at the weekend if you want?
Old 03-02-2010, 07:06 PM   #42
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Cheers Al but think I will get the ecotec one. Heard a few people say they are better than the 1.4/1.6 ones.
Is yours let loose on the road yet?
Old 03-02-2010, 07:11 PM   #43
yep , its the coil i use as well , works a treat. as i had problems using the other type as well
Matt
Old 03-02-2010, 10:12 PM   #44
alexcrosse
CC: 1598
ECU: MBE 967 EF
not loose on the road yet, waiting on lambda controller issues! then engine shimming... think thats it!
Old 07-02-2010, 09:15 PM   #45
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
OOOOOHHHHH its fired up!!! Went to the scrappies for an Ecotec coil pack but no joy so got myself a Ford one. Fitted that and after blowing numerous fuses for the coilpack it settled down nicely with a 15A and tried firing. Coughed and spluttered and died quite a lot before coming to life.
Sounds like a bloody bag of spanners! Very hit n miss whether it starts or not so just upped the Fuel map slightly and seems to have helped.
Problem is if I try n give it any throttle it starts backfiring through the TB's. Now while it looks great its not really what I'm after.
Think I've had mice in my exhaust too as it blew lots of empty sunflower seeds out! LOL
John
