Old 10-01-2018, 11:41 PM   #1
Markwhitt65
ECU: MBE
Default Fitting clubman flip front urgent help please
Hi
Having had all the body shell work done we have now fitted the front metro subframe.
The next step was to offer up the new arc angel fibreglass clubman front what a disaster it doesn’t fit.
Does anyone know if it is possible to trim the subframe front enough to get it to fit under the flip front?
Can I still use the original engine and gearbox mounts?
Am I better having a removable front rather than flip?
Any help would be appreciated one step forward two back !!!
Regards Mark
Markwhitt65 is offline   Reply With Quote
Old 11-01-2018, 01:52 AM   #2
The front cross member of the Metro frame has always been an issue. That's why mine has a forward sloping valance to cover it. I realise this isn't beautiful but it works fine.
If you decide to cut the cross member then you need to replace it with some solid flat bar so that it's close to the exhaust down pipe. It is possible to do this and retain the rear sloping valance. This flat bar is best bolted on as once fitted you would not get the downpipe off should it need it.
Old 11-01-2018, 08:28 AM   #3
People tend to use the ABS front that has the ST Spoiler moulded in as it seems to give the extra room for the Metro frame
https://www.absmotorsport.co.uk/prod...an-st-2-piece/
pics on page in link
Old 11-01-2018, 05:56 PM   #4
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
I shortened the metro frame a bit by chopping off the front bar and re making the engine and gearbox mounting legs, then bolting on a solid front bar. This allows the clubman front to go on, but leaves the bar protruding underneath, hence i fitted a splitter to cover it
I had to cut a section out of the bar to allow the manifold to pass, so i then welded another section of box underneath it at 90 degs to restore the strngth
Old 11-01-2018, 09:08 PM   #5
Markwhitt65
ECU: MBE
Hi
Thank you for the reply I am now thinking I may go for a fabricated steel front.
It will be bolt on with a removable bonnet for general maintenance.
Regards
Mark
Old 12-01-2018, 08:13 AM   #6
I have a welded steel flip front and Metro frame.
I cut the front valance down the seam underneath the sidelights, bent it out to clear the frame, and welded in a fillet piece. Then welded in a plate to give me back the curve, and strengthening gussets inside to make it strong
Hmmm. Tried to upload photos in the usual manner, but not happening. Grrr !
File Type: jpg 85BossToo.jpg (157 Bytes, 78 views)
File Type: jpg 85FrontPanelMod.jpg (157 Bytes, 76 views)
File Type: jpg 93SeamSealFrontPanel.jpg (157 Bytes, 71 views)
Old 12-01-2018, 08:27 AM   #7
Originally Posted by Markwhitt65 View Post
Hi
Regards
Mark
This blog may be of interest
http://www.theclubman.co.uk/project_k8.htm
Old 12-01-2018, 06:36 PM   #8
