Old 04-01-2018, 12:23 PM   #1
ZA-J
Default MPI Ignition Switch with MG Loom
I've got MG ZR loom installed in my Mini, shortened to fit inside the car.
I can't work out how I need to wire the Mini (MPI column) ignition switch to work with the MG loom.
Has this been done before?
Old 04-01-2018, 03:56 PM   #2
yes, i've done a few mpi looms. when you say you have a zr loom shortened to fit do you mean just the engine loom or the whole car loom?
Old 04-01-2018, 04:03 PM   #3
I'm glad this popped up, something on my list of little jobs
Old 04-01-2018, 05:49 PM   #4
ZA-J
Entire loom, just with a few feet chopped out so the two fuse boards were closer together.
Electric windows, air con, mirrors etc has been de-pinned, so its only the MG wiring I want left.
I am left with seven MG ignition barrel wires to be connected to four Mini ignition switch wires.
Old 08-01-2018, 06:59 PM   #5
ZA-J
Anyone able to help with this?
I’m getting close to needing to re-wire the ignition.
Old 09-01-2018, 07:23 AM   #6
I haven't done a complete loom swap so can't really help without spending time looking through the wiring diagrams, I normally use the mini loom and join the k series engine loom into it. I think you will just have to sit down with a copy of the rover rave diagrams and work out each wire
Old 11-02-2018, 03:32 PM   #7
ZA-J
I got the switch working a little while ago, just thought I'd update this thread with how I did it for future reference:
MG Loom : Mini Ignition Switch listed below;
Yellow : White
White/Red : White/Red
Brown : Brown/White
Brown : Brown/Purple
Red : Light Green/White
Black/Yellow : Yellow
Green : Yellow
Old 11-02-2018, 04:12 PM   #8
Yellow : White
Brown : Brown/White
Green : Yellow
Cheers for that!
